Question about Lenovo 3000 Y410 Laptop
My cd rom does not read any cd,when i look for its properties than it says that your device is working properly,why is it so,kindly help me
    President:
  • 1,188 Answers
Verify that the cds you try to get it read are good and possibly check them in another cd rom.
Try cleaning it with a CD-ROM lens cleaner (can be purchased at a local computer store).
Remove it by pressing a lock below the laptop. Follow the instructions for removal in the manual of your laptop. If you cannot do this then take it to a repair shop. The person will assist you in removing it and can fix it.
If the lens is damaged or there is other heavy damage then consider buying a new one.
Posted on Sep 11, 2009
Testimonial: "your advice is very helpfull,but not for me,i don't know which lock are you talking about,but you responded to my quary,that is the best of all"
    Sergeant:
  • 205 Answers
Plse install cyperlink power dvd sofware
My Dvd Writer Can't Read Dvd Disks But Can Read Cd Disks
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps you
Aug 25, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Plays cds but not dvds
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Apr 13, 2011 | Sony (AW-G540A) DVD±RW Burner
My LG DVD Writer can read cd's only, it cannot read dvd's. I have tried cleaning the lense several times, it is no use, kindly help.
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Mar 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
My dvd rom only can read cd. dvd cant read. please help me...
hope this helps
Feb 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Not reading DVD compact disks.
hope this helps
Jan 10, 2011 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Cd/dvd rom will not play or burn
you need a cd\dvd rw to be able to burn as for wont play\read
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no 4 for australia
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Does not read blank disks or dvd's(movie) just does not read
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select 4 for australia
hope this helps
Oct 04, 2010 | Lite On Computers & Internet
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
Lenovo 3000 Y410 Laptop Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
