Question about Kenmore Refrigerators
Kenmore refrigerator 106.72206201 - accumulating ice and water
I have a Kenmore refrigerator 106.72206201 made in 2003. It is now accumulating ice at the top of the refrigerator compartment. Also, water is dripping onto the top shelves and then freezing. What's up with this and how can I fix it?
  • 65 Answers
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Posted on Sep 11, 2009
Where is ice-detecting sensor located in the bottom freezer refrigerator? No ice/water in door, only in freezer (Kenmore)?
On the side of the icemaker, there is a wire bale or arm that is pushed up by the accumulating ice that shuts off the icemaker.
Oct 01, 2014 | Kenmore Refrigerators
Our kenmore top freezer is leaking (dripping water) inside the refrigerator section from around the dial area. Can fill up a small bowl in about 12 to 24 hours.
Most likely your defrost water drain is plugged. You will have to pull the panels off the freezer, to expose the evaporator. the defrost water drains by gravity thru a hole in the pan under the evaporator. Clear it of debris and or ice, check for any accumulated ice. reassemble. Remember to turn off power before attempting repair and be careful not to bend or puncture any refrigeration tubing
Jul 05, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Low water at door. When you push the door water lever, a normal stream of water comes out for half a second and then it reduces to a small stream. Takes for ever to use. The ice seems to be a "hollow"...
Your problem may be a clogged water filter. Change the water filter and recheck the dispenser water flow, and allow new ice to accumulate in the ice tray.
Feb 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer is icing up. Unit is about 2 yrs old
You need to check out the back of the freezer. At the current status, it may be locked with ice. Have it defrosted or just have it melted away. Clean the coils and the entire unit. Either the drains were blocked by food debris or dirt causing water to accumulate and ice to form or the thermistor has been iced or is faulty or too much ice accumulated in the unit's coils.
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
My kenmore is leaking water once a day .
You didn't say from where. Usually twice a day your de-ice heating coils come on and melt any ice that has accumulated. this water usually runs down the back of the ref. and collects in a small pan under the ref. Someime ice form around the hole that the water drains down through to go into the small pan. so then when the deicer comes on the water just runs down the bottom of the ref and onto the floor. My Kenmore does the same thing. Remove everything from the bottom of the Freezer look in the back at the bottom see if hole is clogged with ice. Remove ice then pour hot water down hole check occasionally.
Aug 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
374 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
