Question about NEC VT595 LCD Projector
NEC VT 480, replaced new lamp ,still low brightness.
After replaced lamps,reset lamp working hours, filter working hours, still low brightness, picture Dim.
  • 2,237 Answers
If you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
Posted on Sep 11, 2009
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: http://www.nec-display.com/dl/en/pj_manual/lineup.html . The direct link to the manual for the MT1060 is http://www.nec-display.com/dl/en/pj_manual/mt1065.html .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
Nec vt670 projector , displays "the lamp has reached the end of its usable life.please replace the lamp" the lamp and filter are fine how do i over ride this error
Typically you will need to replace the lamp. Do not try and squeeze the last hour from the lamp as there is now a chance if the lamp will shatter and scratch the mirror and lcd block rendering your projector with a permanent scratch when projected. If you already have a new lamp fittted then simply go to the menu setting, under installation or setup by memory and there is a reset option. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jun 16, 2009 | NEC VT670 Multimedia Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
Lamp brightness
Most projector lamps last approximately one thousand hours. Other possiblity might be the filter that has darkened due to heat.
Nov 24, 2005 | NEC (SPPL1067) Projector Lamp for MT840,...
NEC VT595 LCD Projector Logo
1,599 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
