Question about Apple Macintosh Keyboard
If i press 1 key it appears 2 keys
EG.
If i press s it appears as sg If i press w it appears as wt If i press t it appears as wt If i press x it appears as xb I have problems only in 2 columns column 1 : 2wsx column 2 : 5tgb other keys are absolutely find. Kindly find a solution,....
  • Apple Expert
  • 481 Answers
Your keyboard is broken and needs to be replaced.
Posted on May 17, 2010
    Problem Solver:
  • 16 Answers
You need a new keyboard. The keypress decoder inside the keyboard has obviously developed a malfunction. It is NOT repairable. Buy a new keyboard.
Posted on Sep 22, 2009
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
How to change time and date
Follow this procedure to set the current date and time.
1. Open all three one-touch speed dialing panels.
2. Press [Data Registration]
3. Press [up arrow] or [down arrow] until <TIMER SETTINGS> appears, then press [Set]
4. Press [up arrow] or [down arrow] until <1.DATE/TIME SETTING> appears, then press [Set]
5. Register the current date and time using the numeric keys. Use 24-hour notation to enter the time (eg. 1:00pm as 13:00)
You can also press [>] or [<] to move the cursor without changing a number entry. To restore the previous entry, press (c) (clear)
6. Press [Set]
the message<DATA ENTRY OK> appears on the screen for a few seconds.
7. Press [STOP] to return to the Standby Mode.
May 13, 2011 | Canon MX700 Office All-In-One InkJet...
Need a manual for altech althc014. have no idea how to use it. can't work out how to just turn on without the timer!!
Ive been having the same problem! I found these instructions on a forum if it helps-
To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Sep 27, 2010 | Heating & Cooling
How do i calculate permutation in fx-82ms casio calculator
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Aug 11, 2009 | Casio FX-115ES Scientific Calculator
Zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
May 18, 2009 | House Brand Heating&Air Conditioning...
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Security code for Nokia 2100
The main code used in Nokia phones is :
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx
1. Insert SIM card of different provider.
2. Turn on the phone and press the UP VOLUME key for 3 sec.
Then release it and the phone says PIN CODE?
3. Press the "C" key.
4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option !
Dec 17, 2008 | Nokia 2100 Cellular Phone
CASIO TK 7000 cash register how to change the time
pgm 1
enter 24Hr Clock
0900 or 2100
press the date/ time button
next to the C Key on standard keyboard
Nov 11, 2008 | Computers & Internet
Gprs
you will need to ask your service provider to send you the GPRS/WAP settings for your handset.
they will text it to you, and then u save them and it will be listed in
Menu > Settings > Configuration > Default
select that setting and set it to be the default setting and then click on Act. Def. In all applications (this will activate default settings in all applications that use GPRS)
or if u knew the access point settings and all, u can add a manual setting and make that as default.
cheerz
Apr 28, 2008 | Nokia 7610
England football tv remote
if this is the one i have just bought then you tune it by:
1. Press desired function (eg tv)
2. Hold down P+ and VOL- simultaneously for 2 seconds until indicator lights up
3. enter 4 digit code, indicator will go out
4. test if remote works.
if your code dont work you can try the scan option, not sure what its called, sorry
3. enter a magic search code from these
a. tv=0001
b. vcr=0002
c. sat=0003
d. ctv=0004
e. dvd=0005
(eg press 'TV' device key, then P+ and VOL- and enter tv magic code 0001)
4. Press same desired function key again (eg tv)
5. Hold down P+ and VOL- simultaneously for 2 seconds until indicator lights up and the remote is ready to search
6. pres the england key repeatedly until device turns off
7. immediately press P+ and VOL- when the device switches off to lock in the code.
Hope i have helped with this.
Craig
Sep 23, 2007 | Televison & Video
Apple Macintosh Keyboard Logo
362 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
