Question about Refrigerators
Amana not cooling , temperture led setting is just showing a bar
  • 221 Answers
If your display is showing "--" It means the unit is turned off. If it does not come on by pressing the up arrows, the board is either locked or failed. Unplug the unit for 30 seconds and plug it back in. If pressing the up arrow still does not turn the unit on, then you have to replace the control board. Your unit has what is called the "JAZZ" or "mid level control".
A new board must be programmed with the personality code shown on your Model/Serial tag in the fresh food compartment. Instructions for entering this code are included with the new board.
If you attempt this repair yourself, make sure power is removed from the unit first, and do not handle the board except by the edges, as static discharge from your hands could cause damage to the components.
Posted on Sep 11, 2009
Testimonial: "unplugged and replugged came back on, working agin so far thank you!"
When the system is in the heating mode of operation and a dirty indoor coil is present, the system will have high sub-cooling?
subcooling is only a factor in the cooling mode. you convert the discharge psi to temperture and measure liquid line tempsrture. subtract difference it should be between 8 to 12 degrees.
Jun 09, 2015 | Amana PTH123B25AJ Heat Pump Air...
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Installed Amana PTAC DigiSmart unit in a patio room, a entertainment bar is located about three feet (3) in front of unit and not the room. The unit only heat and cool the area between unit and the bar...
I have seen this happen many times and if you cannot relocate the bulb of the thermostat to keep it form short cycling, I have mounted a wall thermostat and disconnected the thermostat in the PTAC and wired it in to the wall stat. You may have to install a wall stat in the center of the room away from the bar.
May 15, 2011 | Heating & Cooling
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
How to get temperature reading on thermostat after a power outage
Normally the room temperture shows in display and setting temptr blinkering while you press the setting
Dec 02, 2010 | Honeywell Electronic Programmable...
Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
Jan 26, 2008 | Amana AFD2535DES French Door Refrigerator
No Cols - Temperature Controls do not respond - LED display shows a dash "-"
pencj,
My honest answer is that I have seen this before and in most cases the board works properly after the reboot.
Although you may not have lost power, you may have gotten a voltage spike. I would cancel the service man coming out, (I am a working service man myself) he probably will give you two options. #1 Wait to see if this happens again and if it does happen again soon, the board should be replaced. #2 replace the board now.
My suggestion is to soon go purchase a surge suppressor to plug into. This does not need to be a power strip style. A good quality suppressor that only has one or 2 plug in's or plugs directly into the wall receptacle should do fine. Your refrigerators maximum amp draw is listed on the model # sticker inside the refrigerator compartment.
I hope this helps, supertechks
Jan 26, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana ptac
WHAT DID YOU DO TO IT?
Sep 10, 2007 | Amana AAC051FRB Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
