Question about Lexmark X5470 All-In-One InkJet Printer
Stupid pritner Help, i tried to print my work but i can't, do i need to have a driver or something??
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
May 01, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Epson iii & 4 printers prints slow
Try printing something that is formatted properly to fit on a receipt roll printer. the Windows test page will always be slow on a receipt roll printer, because it is formatted for 8-1/2" X 11" pritners and contains graphics. I suspect that actual printing will be fine.
Jun 30, 2010 | Epson TM-T88III (C420863)
Prints half the picture
Most of these issues are caused by drivers in the computer that are not agreeing with the pritner.
I would doubt its something hardware as its prting half.
it also could be a setting.
let me know
Thanks please do leave ratings and feedback
May 08, 2010 | Kodak EASYSHARE Plus Series 3 Thermal...
My HP 8500 stopped printing my Quickbooks 2009 checks. It worked fine for about 5 months and then stopped. I installed updates for both Windows and QB 2009 and reinstalled the HP drivers for my printer but...
click on start go to control panel. go to pritners. click on add a printer option on top of window. then add a local pritner. add deskjet 990c drivers use existing ports
Dec 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Error message bad esc seq
The Bad Esc error you are seeing indicates the pritner is reciving data from the host computer system that it does not recognise, the most likely cause for this error are;
  1. You are not using the correct pritner driver to print to the pritner
  2. The Emulation setting on the pritner is not correct, you can check this via the printers menu - I would guess the pritner has defaulted to MT660 emulation and it needs to be set to Epson or IBM emulation
Nov 17, 2009 | Tally MT661 Printer
J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
Oct 29, 2009 | HP DeskJet 648c InkJet Printer
We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
It would be strange for the printer to print dot between each printed character without this coming from the system.
As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
To print a menu print put the pritner OFFLINE
Press SETUP
Press the button under MENU
Press the button under PRINT.
The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
If the menu prints OK, then there is some sort of other strange system or communication problem.
If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
Check the emulation setting on the pritner ensure this is correct.
Aug 02, 2009 | Epson Stylus Photo 2100 InkJet Printer
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
