Question about Exercise & Fitness
I need aSSEMBLY INSTRUCTION FOR A Ni Trac GYM
I need aSSEMBLY INSTRUCTION FOR A nI TRAC GYM
  • 1196 Answers
SOURCE: Hi i'm looking for an
You can check for the instruction manual of how to assemble your unit at manualsonline.com Let me know if there is anymore help i can render.
Posted on Dec 01, 2010
  • 14 Answers
SOURCE: Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Posted on Jan 05, 2009
salvidordali
  • 103 Answers
SOURCE: 2001 pt cruiser (TRAC button )
the Trac button disengages the Traction Control System. I think some engineer installed this button specifically for teenage boys. I would keep the traction button on as it will help you in bad weather to reduce the chance of wheel spin.
Posted on Jan 10, 2009
  • 7 Answers
SOURCE: VSC TRAC and TRAC OFF lights
you need to have the computer reset.
Posted on May 26, 2009
  • 49 Answers
SOURCE: york barbell 2002 home gym,no assembly instruction
http://www.yorkfitness.com/store/IIT_Instructions.asp
Foolow the link and select home gyms. Assembly manuals for individual models listed.
Posted on Aug 31, 2009
Ni-Trac VA-500 exercise bike ( which I bought 2nd hand, in good condition) resistance has stopped working
If it was clicking the resistance motor is stuffed replace it they are quite cheap and easy done, but also make sure the flywheel is tight as they loosen over time as well. You'll need the crank tool, I made one from a m20 metric fine thread and drilled and tapped but you could probably get one from a local cycle shop. Easy job, worth doing these bikes are real nice ??
Jan 30, 2015 | Exercise & Fitness
Heater core replacement on a 2003 ford sport trac
the complete climate control assembly unit is required to be removed in order to remove the heater core. The climate control assembly is attached by studs & nuts which are accessible at the firewall in the engine compartment. The R134 refrigerant will need to be evacuated and the a/c lines at the expansion valve removed in order to remove the climate unit. Hope this helps. :)
Jan 21, 2014 | 2003 Ford Explorer Sport Trac
I need manual for lb4
It will show Battery Protect when;
1-There are no batteries in unit.
2-The batteries are fully charged.
3-Alkaline batteries have been installed and charging is attempted.
4-The batteries are bad.
Sanyo 4400 Ni-Cads assembled in brick pack form, the Ni-Cads normally last 3-4 years and need replacement. This is an older unit that is obsolete with few parts available but there are after-market battery assemblers that can make them up just Google it.
Aug 27, 2012 | Leica Laser Alignment Lb-4 Dual Grade...
How to assemble a DP Fit for life dual trac 20
dp trac 20 weight lifting mechine how can i assemble
Dec 18, 2011 | Cars & Trucks
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Star Trac Pro Climber Stair Stepper Sc4130: I have no resistance on my star trac pro upright b...
Star Trac pro unit do not have a alternator and this problem is a lower board issue depending the version their is a 2 watt resistor has over heated meaning a component or components has shorted. I don' know but I believe that National Gym Supply may be able rebuild for a lessor amount and new board will cost $355.00 give them a call @ 1800-496-7278
May 18, 2010 | Startrac Fitness Products Sc4130 Star Trac...
Error code EL 2 ?
EL 2 Error code means an erratic reading coming from the elevation potentiometer. Unfortunately that means a replacement of the motor Star Trac does not sell just that one part. But you maybe able to send the motor to be repair for aabuot 1/2 cost of a new one. Call this # 1800-496-7278 conpany's name is Nation Gym parts they can help you
Jan 19, 2010 | Startrac Fitness Products Star Trac 3900...
Multi gym
I have the multi gym at home all set up.. can send pics of it..
Sep 05, 2008 | Sport & Outdoor - Others
Exercise & Fitness Logo
672 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
