RE: Philips pc9227c121 I cannot find too much about this TV. It appears it is for commercial purposes (hotels etc.), this may be why there are no video inputs. A suggestion may be to run it through a VCR with RCA inputs, or possibly a switching box.RE: Philips pc9227c121 I cannot find too much about this TV. It appears it is for commercial purposes (hotels etc.), this may be why there are no video inputs. A suggestion may be to run it through a VCR with RCA inputs, or possibly a switching box.
The tv should have several hdmi sockets. If Phillips DVD has hdmi use that. If Phillips is old then you will have to connect it with the yellow, red and white outputs to the corresponding on tv.
To play you will have to push input button on remote and select AV.
Ur tv have a RCA INPUT holes like Y,R,W INPUT holes from the Front or the Back of the tv wright?Yes.U must buy or have it already a RCA components cable Y,R,W wires.Connected the RCA components cable Y,R,W wires to the DVD player Y,R,W OUTPUT holes and the other end of the RCA components cable wires Y,R,W connected to the tv Y,R,W INPUT holes.Now the tv and DVD player is on ok.Now u playing the DVD player contents Disc and push the INPUT modes on the tv like VIDEO 1 or 2 by the tv remote or manual button on the tv.Now u should have video picture of the DVD Disc contents playing.
Connect you vcr audio video output to tv audio video input and turn it on. On your tv menu select video input. If you see 'tv\video' on the button switch of the remote control or tv switching panel, press it.
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
Initially, the video (yellow) and audio (red & white) OUTPUTs of the cable box should go to the Video/Audio INPUTs of the RF Modulator. Thereafter, the TV should be set to Channel 3 (or whatever it is the RF Mod is using). This is done if and only if the TV has no A/V INPUTs and/or the cable box has no RF OUTPUT.
Good luck and Thank you for using FixYa. Happy Holidays.
Take a flashlight and magnifying glass and look at the S-Video connector on the back of the TV. Check to see that there aren't any pins or other debris stuck in the four holes.
One pair of holes is for the brightness (luma) signal, which gives you the black and white picture, and the other pair of holes is for the color (chroma) signal, which seems to not be functioning.
If there's nothing in the holes, then the internal connection may be flakey. Try gently wiggling the plug on the TV side and see if color returns, even briefly.
Does your TV have other inputs like component YPbPr?
More details please. Is it a CRT or LCD TV?
