Question about Zenith DVC2550 Multi-disc DVD Player
Unit has power but inoperable
Hi The unit froze while playing a DVD. Eventually had to take apart to retrieve disc by manually operating gears to remove head from disc. Nothing appears to broken or jammed. When unit is turned on, nothing happens, display is lit but does not display the usual info, cannot open disc tray, etc. Local repair shop says too expensive to fix but it seems such a waste to throw it out when it was working perfectly until it froze. I think it's just not initializing properly but need schematic to see how to reset. Any suggestions?
  • StanU Jul 28, 2008
    yes same problem ,unit froze al display lights on and all 0000000 showing!Contemplating disassembly to retrive DVD's seems this has occurs frequently on this Model any zenith response???
    Top Expert:
  • Zenith Master
  • 75,846 Answers
SOURCE: XBV442 DVD door won't open
I have opened many a player and given the tray a slight assist. Voila it unsticks
Posted on Mar 25, 2008
worldvet
  • 859 Answers
SOURCE: DVD tray will not open.
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Regards,
Worldvet
Posted on Jun 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Finalizing DVD
If the size of the vhs recording was in 2hr mode, and the size of the recording itself is about 2 hrs, you may not have enough space to finalize. I would use your PC to finalize the disc - I use Dr. Divx, but you can find many finalizing programs out there.
Posted on Sep 04, 2008
SOURCE: DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Posted on Sep 08, 2008
Locoman21007
  • 8 Answers
SOURCE: Reposting my Zenith XBV 342 DVD/VCR problems.The
for the dvd player could be that your tray moter died or losend. take it to an electronic store.
Posted on Jun 22, 2009
My LG RH4820w DVD player freezes while playing back DVDs. I can can get it to power off and on by holding the "Power" button down. I can then start playing the DVD again, but it eventually...
Sounds like the laser might be going out or dirty. You could try blowing some air in there to try and remove dirt. If that doesn't help then it might be going out.
May 04, 2011 | LG RH-4820 DVD Recorder
Paused a disc ,when i hit play,the play light came on but nothing happened. I cannot turn off the dvd play manually. it seems to be frozen.have chaned batteries
Hi:
Try disconnecting the unit from any power source and waiting for at least 10 mins before restoring power. This should reset the units microprocessor so you can resume playing.
May 01, 2011 | Samsung DVD-1080P7 DVD Player
DVD player suddenly stopped working
Turn unit off and unplug, then plug back in and keep finger on eject button, and then hit the power button.  Nothing?  Get your phillips screwdriver and remove the shell.  Then retrieve you disc.  While your in there look for signs of a burned capacitor off the ic port chip and take a little glass cleaner and clean the optical lens with a micro fiber cloth.
Nov 15, 2009 | Philips HTS3500S System
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
DVD will not eject
Power off the unit, if it will not power off, unplug the unit for a few minutes, then plug back in.
press the power button (turning it on). Before it can attempt to read the disc, eject it.
Feb 16, 2009 | JVC HR-XVC27U DVD Player/VCR
VR357 is froze up
Try resetting the unit.
Press and hold FF and RW on the player (not the remote).
Jan 21, 2009 | Samsung DVD-VR357
TruTech Malfunction!
You could try using a laser lens cleaner.
Radio Shack makes one called "Carbonedge"
The RS catalog # is 42-209.
Whatever you do do NOT take the unit apart and try to clean the laser lens by hand. It is easily damaged.
Apr 14, 2008 | TruTech TT320
PS2 problem
It's likely the lazer lens is out of alignment or requires replacing. Did your dvd cleaner also have a lens aligning part to it, you normally go through a spoken instruction(go to track 2 etc), as cleaning is sometimes not the only required solution.
Jan 08, 2007 | Sony PlayStation 2 (PS2) Console
Zenith DVC2550 Multi-disc DVD Player Logo
87 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
