Cannot open kenmore 11022722100 control panel
  • 5,911 Answers
Your control panel has removable end caps. Those are the two white plastic trim pieces at each end. The end caps will pop off by grabbing the top part and pulling it towards you. You can place a flat blade screwdriver in the top groove in the rear of the panel and give it a slight twist to pop it free, if you can't get it to come off by hand. With the end cap removed, you should see a screw. There's one on each end. Loosen these screws and the panel will lift up and and fold back over the back panel. Use care not to damage the small hinges (if equipped) that hold the operator console to the washer top.
If you need an illustration to assist you, go to searspartsdirect.com and type in your model number. There are helpful exploded view diagrams, with parts listings, of each section of your washer.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Posted on Sep 11, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Dryer door does not open
I think Kenmore is essentially a Whirlpool. Make sure the controls are not "locked". Read the control panel thoroughly to be sure.
Feb 27, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore washer model 11022722100 wont spin out wet clothes
the PCB has a problem and only a certified tech should try repairs
Sep 13, 2017 | Washing Machines
What size tub is my kenmore washer model 11022722100
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 26942503 washing machine cycle dial too loose
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26942503+
See the section on the control panel.
There are clips under the control panel that will pop loose is you use a thin putty knife to push on them from the front. Then the control panel should swing up.
Oct 12, 2009 | Kenmore Washing Machines
Speed knob and stem broken from Kenmore washer Model #11022722100. What parts do I need and how do I replace parts on washer.
While the speed knob and dial are relatively inexpensive, the "stem" you refer to is actually the washer Timer which sells for between $100.00 and $150.00. You can find appliance repair parts at http://www.partstore.com/
May 23, 2009 | Kenmore 22422 Top Load Washer
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 2.1 cu. ft Washer water won't stop filing, cycle doesn't start...
most likely cause
kenmore pressure sensors work off a tube that runs from the bottom of the drum to the sensor, either the tube has come off the sensor body inside the control panel
  • open control panel reattach tube, wrap wiretie or twisttie to keep in plpace
or less likely cause
kenmore level sensors fail
there is a spring inside that stretches over time and mis reads, it is adjustable
  • control panel is still open from previous check
  • remove level selector from control panel, usually an unlock latch on the right side, rotate 45deg counter clockwise withdraw.
  • there is a 1/8 inch bolt head, turn right raise water level, turl left lower water level
Aug 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
