Question about Yamaha Full-Size Keyboard
Some times tha accomtation chord is not working .why?any solvatation is there
  • 788 Answers
The keyboard may have picked up some dust and not making good contacts.
You mite try a high pressure blowout. or you may think about takeing it apart and giving it a real cleaning.
Good luck.
Posted on Sep 11, 2009
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 | Casio Music
What are all the left side controls on an Elegance JC-618 electronic keyboard
Single and Finger,is chords mode.
In Single,by press one key (eg:A) then chords A is heard,and so on.
In Finger,you must press 3 keys.Example: G-B-D,then you heard G chord. D-F#-A is D chord.
In Finger,lets say you press A chord and want to change to C chord by press one key C only,there's nothing change untill you press C-E-G.
Low, is for chords octave low.
Chords Off,no chords can be play,it mean overall full piano mode..
Single,Finger,Low, can be activate with Sync Start button.
Aug 17, 2015 | Music
The ACMP function doesnt work when I play, even tho it says it is on in the display window
Check you have selected 'sync start'. The ACMP selection activates the automatic chords but not the rhythm, so each note produces a droning chord. Sync start activates the automatic chords and rhythm you have selected when you play anywhere near the bottom end of the keyboard. Alternatively you can manually press play to start the drums by themselves and then the chords will begin the moment to play with your left hand.
Mar 12, 2015 | Yamaha PSR-E413 Portable Keyboard
Ultimate guitar guitar tabs
Here are the chords:
http://chordsworld.com/the-madden-brothers-we-are-done-chords/
Don't be confused by the video. The guy is capo'd up a whole key, so his fingered G actually is the A shown on the chorded lyric sheet.
Enjoy.
Jul 24, 2014 | Homespun The C-A-G-E-D Guitar System Made...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Hi The first 11 keys of our keyboard have not woked since new. If my girls press the play/pause button then it works. Is this a fault of the keyboard or are we doing something wrong? Thanku
Check the switch to be sure the keyboard is in normal mode and not chord mode. This will cause there to be no sound unless you play a chord on those first 11 keys. Pressing play activates whatever song is loaded at the time, allowing full keyboard use.
I have an older Casio, and the same thing happens all the time, especially when I'm in a hurry and don't check where I put the switch.
Hope that helps!
Feb 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
How do you change your chord set-up on an autoharp and is there any reason not to set it up like a piano keyboard (C-D-E-F-G-A-B)? Thanks in advance.
An autoharp makes chords by muting all the strings except those that make the chord. There would be 2 ways to change the chord structure. 1) retune the strings knowing which ones will be muted by each key so that the result is another but valid chord or 2) make your own "keys" so that they mute different strings.
The tuning of an autoharp is selected to allow you to play songs as long as they are in the right key or two. If you set it "like a piano" as you suggest, you could play those chords but not the chord sequences that make up most songs. Most songs revolve around sequences or intervals such as the popular 1 - 4 - 5 blues progressions. Most music has some predictable progressions and that's why the autoharp is tuned the way it is.
You can always experiment with different and odd tunings but if your goal is to play already written songs, I'd stick with the normal tunings - there are alternates.
Jan 29, 2011 | Oscar Schmidt Autoharp
Casio tonebank ct700 no sound from chords only whilest on fingered chord please advise
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
Sep 27, 2009 | Casio Music
No chord will play while in fingered mode it is a casio tonebank ct700 model
NORMALLY "fingered" mode means that you have to "finger" the chord, that is, play all the notes of the chord. It sounds like it IS working as designed.
Guitar chords
Do you mean like that?...
  • CHORD A
E---|---|---|---|---|
B---|---|-x-|---|---|
G---|---|-x-|---|---|
D---|---|-x-|---|---|
A---|---|---|---|---|
Sorry if this isn't what you mean :) xxx
Jan 24, 2009 | Yamaha Electric Guitar
Yamaha Full-Size Keyboard Logo
44 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
