Question about Panasonic PT-P1SDU Multimedia Projector
Panasonic PT-P1SDU, How to remove/solve 2 verticle line on screen travels from bottom to top, seem to be part of the image refreshing but it's distracting ? thanks
  • birtch762 Sep 11, 2009
    bulb only has 48 hours on it.
  • 2,237 Answers
First reset the settings to factory default. if that doesn't help and you also have it on the title (splash) screen, one of the ribbon cables for the lcd panels may be loose. you'd need to remove the cover and reseat the cables.
Posted on Sep 11, 2009
I have RED verticle lines all the way across the screen fro top to bottom 10 minutes after I turn my Panasonic PT-52LCX65 TV on. Is there a solution?
Hello
Check and replace the main filter capacitor in the power supply section. Replace all of them in the secondary section of the power supply too. The problem is due to insufficant smoothing and regulatio fo the power supply section. If main smoothing capacitor gets value deveoped, it won't supply enough voltage to the switching section, and switching section also will go inefficient. Replace all of them. It won't cost not much. OK.
Jun 22, 2011 | Panasonic PT-52LCX65 44" HDTV
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-AE900u Horizontal Ghost Image/ 2:35 Image Retention.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Jul 21, 2009 | Panasonic Televison & Video
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
129 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
