Trying to boot up my Windows XP PC - Vaio. Getting error messages that virtual memory is too low, then when I click that away, the screen is just black and I can move the cursor around, but that's it.
  • Mitesh Kr Anand May 11, 2010
    What is the Model # of the Computer?
  • 788 Answers
Well your not really telling us anything helpful.
How much memory do you have, and how much memory does the unit see in the BIOS.
I don't remember how to get into the BIOS on the VAIO units, F-1, F-10 or Del ??
In the BIOS, you should be able to see how much memory is beeing seen by the unit.
I would remove the existing memory and re-install or reseat.
If your VAIO see's the amount of memory you have installed, your good to go. If not, you may have a bad memory stick.
After checking the memory, you may want to boot into safe mode and see if the unit has any other complaints. Device Manager.
good luck
Posted on Sep 11, 2009
    Sergeant:
    Champion:
  • 208 Answers
If you have at the least 512m of RAM, your laptop should boot without any virtual memory. Anyway, virtual memory is a method of using your hard drive to function as RAM, though much slower. When you have very little RAM, say less than 128m, and without enough hard drive space, you system will not boot.
If you have 512m of RAM or more, your problem maybe more complex to resolve. How much RAM do you have? How big is your drive?
What you need to do next depends on how much RAM you have.
Hi. I have windows XP 2007. Each day, when I first log on, a message says: "Virtual memory too low. Windows is increasing memory on your paging files." This takes an hour. If I reboot during the same day,...
Google "virtual memory too low solution." Trusted sources are PC Magazine, Microsoft...
(In my case, I ran "msconfig", go to "Start up" tab and uncheck programs I did not want Windows to load at boot. That would free up memory.).
Aug 22, 2010 | Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
What kind of memory module can i add to increase my memory for a hp pavilion a305w. when I am playing games online it says virtual memory low..
Virtual Memory (or Paging File) is controlled on your computer and is actually space on your hard drive. In windows XP, go to START, right click My Computer and select Properties. Under the Hardware Tab, select Settings under Performance. In the Advanced Tab, under Virtual Memory, select Change. Set the Paging File Size to "System Managed". Click Set>OK>OK>OK.
This error should go away now, unless your hard drive is getting full. Check to make sure that you have at least 25% free space on the hard drive where the Paging File is set up.
Did this solve your problem? If so, please rate this. ty.
Feb 26, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
I get a "virtual memory is low" error message. How do I correct
You have two different & independent problems. I will solve them one by one.
First of all, for increasing VIRTUAL MEMORY you should Right Click on "MY COMPUTER" then choose "Properties", then goto "Advanced" tab and then in "Performance" frame click "Settings" and then again goto "Advanced" tab and there you will see a "Virtual Memory" frame and then click on "Set" and increase the size of your virtual memory.
Second problem is due to installing many instances of XP. You can re-format your whole drive again and you will enjoy a fresh & single copy of XP again.
if you finds any difficulty or any doubt is there then feel free to contact me again.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 29, 2009 | Dell Inspiron 1300 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
I have windows xp service pack 2 I keep getting the error message the my virtual memory is low. How do I fix it.
Go into control panel, system, advanced. Under system performance, click settings. Click on advanced and under virtual memory click on change. Make the initial size 1024 and the max size 2048. Click okay on everything to get out of there. Reboot your computer and you're done.
Jun 29, 2008 | Northgate Computers & Internet
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
