Question about Sony Cyber-shot DSC-W200 Digital Camera
DSC-W200 Frozen My W200 has the lens open (extended) and will not close. Additionally, when I press the power button or the play button on the back, the LCD lights up and says Sony, but nothing else happens. I've tried connecting it to my macbook, using a fully charged battery, memory card vs no card, etc. Nothing seems to work. If I press the power button a seond time, the green power light goes off, but the LCD still says Sony. Any help would be greatly appreciated. Not too eager to send it back to Sony since I've had it for about 1.5 years and am sure the warranty is up. Thanks, AJ
  • ahopp Sep 12, 2009
    Just to clarify. I'm going to "firmly slap"the side of the camera against my palm, and not the lens...right?
    Thanks, Nettiser, I'll surely post regardless of where it works or not.
    Brigadier General:
  • 4,090 Answers
Try this it works for lens problems like you describe ]]]
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
let me know if this worked for you Cheers
Please rate our help to keep the service online ++++ Thanks for using Fixya
Posted on Sep 11, 2009
The camara got wet. We removed the battery and let the camara open (lens out) to get dry. After it was dry, we put the battery back in (fully charged) but we can not close the lens any more. Non of the...
I would put the camera into a bowl of rice (sounds crazy, but it works). The rice will **** the remaining water from the camera. If you are still having problems you will probably need to replace the camera.
Aug 05, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
Sony Cybershot DSC-W200 digital camera. Suddenly and for no apparent reason it can no longer be switched on. Blank screen, no lens movement, no sound, totally dead. I substituted a spare, fully charged...
Try this:
Remove the batteries at the same time that you remove the camera's memory card. This will allow the camera to reset. The camera does not require the memory card to operate, so leave the memory card out as you reinsert the batteries. If the camera turns on with the memory card out, but not with it in, you may have a corrupt memory card. Contact the memory card's manufacturer for a replacement.
Turn on the camera in playback mode. This mode allows you to turn on the camera without extending the lens. If your camera is already set to playback mode, it may appear the camera is not turning on when you press the "on" button, because the lens will not extend.Contact Sony if your camera still won't turn,if you bought your camera new from a licensed retailer, it should come with a one-year manufacturer's warranty. Sony Consumer Direct Return Center
10227 Crossroads Loop, Suite D
Laredo, TX 78045
1-800-236-1877
Sonystyle.com
Mar 24, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
Sony DSC-W70 digital camera - Lens attempts to open when pressing the power button but fails with a message to turn off and back on again. Bought a new battery and still does the same thing. Sometimes...
That's a common problem on Cybershot cameras, happened to me twice, the solution is to get it to a camera shop for repair.
The cause could be dirt or a malfunction on the lens extending mechanism.
Mar 10, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
My camera stopped working suddenly. When I turn
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jun 01, 2010 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
DSC -w200 english language support
Hit the home button hit the right arrow button 4 time, then down 3 now hit the center button, now right 1 time now hit the center button and choose english and the center button again and then home.
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 21, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Zoom
It looks like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse
Sep 10, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot  DSC-W200 Digital Camera Logo
251 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
