Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi Projection TV WD-62525
Return from 30 day vacation, tv picture&sound did not come on. Lamp statu was red; Replaced lamp with new one provided by Mitsubishi - no change i.e., no picture no sound. Disconncedted, reset no help...What else beside a bad lamp would cause a red lamp status? Haven't been able to find a qualified technican in the San Antonio, Tx area.... Tony I REPLACED MY DLP LAMP WITH A MITSUBISHI LAMP,TURN THE SET ON AND EVERYTHING WAS FINE TILL YOU TURN THE TV OFF.WHEN YOU TURN IT BACK ON WE HAVE SOUND BUT NO PICTURE.IF YOU PULL THE LAMP OUT AND REPLACE IT IMMEDIATLEY THE TV WORKS FINE TILL YOU TURN IT OFF AGAIN THEN THE SAME PROBLEM.IT IS FRUSTRATING TO HAVE TO PULL THE LAMP OUT AND REPLACE IT EVERY TIME YOU WANT TO WATCH TV.
    Genius:
  • 1,153 Answers
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Posted on Dec 10, 2007
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 PROBLEM
YOU NEED A FIRMWARE UPGRADE FOR THIS MONITOR.
SERGIO
Mar 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
Dec 10, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
221 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
