Computer wont boot properly
I'm trying to get an old computer to work but it wont boot up. This is the error I get...
RPL-ROM-ADR: 000A E6C6 6A79
RPL-ROM-IRQ: 12
RPL-ROM-PIO: D400
RPL-ROM-FFC: 1
I tried to do a full installation using Windows XP, but as soon as I enter Setup, I get a Blue Screen of Death (BSOD).
I checked the BIOS and my Primary Boot device is set to Floppy, Secondary as CD, and Tertiary as Hard Drive.
Currently I have removed the battery from the motherboard, as this may solve the issue but if anyone knows the fix to this problem Please guide me. Thanks
  • chotomoto Sep 11, 2009
    I have tried all the steps as you suggested, couldn't find anything unusual but now when I insert the windows xp boot cd, my PC simply keeps on crashing, showing the BSOD..with this error
    acpi.sys- address F74C4CD9 base at F74BE000, datestamp 41107d27
  • 32,281 Answers
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Posted on Sep 11, 2009
  • Chris Hingee
    Chris Hingee Sep 11, 2009
    You could have faulty RAM module/s, try different RAM modules, make sure they are the same speed or faster.
    Scholar:
  • 53 Answers
Firstly, check if Floppy drive physically installedin that PC, if not, then remove it from BIOS also. Second, check the Master/Slave jumper configuration on the HDD and CD drives. If they are connected each by own flat cables, they both shall be MA, otherwise, if they both sitting on same cable, make HDD - MA and CD - SL. Make sure they appears in the BIOS same. It also possible your HDD has physical damages on the disc. In the BIOS settings enable SMART function and when booting, keep finger on PAUSE/BREAK button, stop boot process when table shows up, there you will find SMART function report about HDD condition.
Also when you install fresh Windows XP, select New Installation with deletion of previous copy, and FULL FORMAT of HDD (not Quick Format) - this will isolate HDD errors if any.
In case if that HDD may have valuable info, connect another hard drive as master and keed old one as slave.
    Problem Solver:
  • 7 Answers
U donot mention your computer configuration properly .if your computer is pIII then your RAM of the computer should be minimum 128 for installing winXP SP1 but recommended RAM 256.
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
After installing sd-via-1a5e1ir boot up gives -- pxe-2.1 build 083 wpm 2.0 rpl v2.74 110-out of memory space for option roms. rom unable to run due to memory constriants. bus/dev/fcn:...
Give this a try:
Restart the computer and enter the BIOS screen by pressing the F10 key at the first screen.
In Computer Setup, set Advanced > Device Options > NIC PXE Option ROM Download to DISABLE to prevent PXE option ROM for the internal NIC from being downloaded during POST to free more memory for an expansion card's option ROM. Internal PXE option ROM is used for booting from the NIC to a PXE server.
May 03, 2011 | SYBA SD-VIA-1A5E1IR PCI SATA / IDE / USB...
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
Solutions
Feb 19, 2011 | Microsoft Computers & Internet
My computer wont start...it keeps saying missing NTLDR?...what do i do?
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Sep 20, 2009 | Computers & Internet
Windows will not start
hi
this error says that the explorer file of the Operating system has gone corrupted .
first try to restart the computer in safe mode .
once you press the power botton imediately start pressing F8 for 10-12 times it will give you a advance boot option form their try to select safemode with networking check that wether under that condition the computer is working or not
if not then
try to change the boot oder of the computer in bios and change the booting option from hardisck to cd rom .then put the Operating system cd into the computer and them try to click on to repair option while the computer start by doing this the old explorer file will be replace by the new one
Jul 09, 2009 | Acer Aspire 1690 Notebook
Wont recognise disk drive ide error
What you need to do is edit the BIOS so that the computer boots from the CD-ROM initially rather then the harddrive.
To do this follow these instructions:
1. Start the computer and tap the F2 key
2. You will now be in the computer BIOS, look for the option that says "Boot Sequence"
3. Highlight the option that shows your CD-ROM device and tap the "F5" key until it is the first one on the list
4. Hit the "Escape" key and select the option to "Exit & Save Changes".
If you restart your computer it should now boot from the CD-ROM. If you have any problems let me know and I will be more then happy to help you further troubleshoot!
May 05, 2009 | Computers & Internet
Can't enter Setup.
This may be an obvious question, but did you check the jumpers on the Hard drives? Make sure the master is set to master or to CS (cable select) then try again.
Jan 28, 2009 | Computers & Internet
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
Solutions:
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Weird error message on boot. BIOS error?
This is a strange one. Does the BIOS on your motherboard detect your hard drives at all? I'd try the lowest level first. If so, then try to boot from your XP CD ROM (hopefully this should work). Try to go into recovery console to see if your hard drive can even be mounted by the system. I'd check there.
If you still have issues,try to reflash your mobo BIOS to the most current one. Could be a flaky BIOS issue.
Feb 06, 2008 | AMI American Megatrends UltraSCSI...
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
