Question about IMSI TurboCAD Full Version for Mac
Text disappears from screen
I enter text the press 'return' and it disappears from the screen. Can someone help?
When I text on my blu 5.5 it disappears
What make of laptop is a blu 5.5?
Jul 24, 2015 | Computers & Internet
What is the unlock all for dirt to Daytona
At the title screen after the press start screen you will see three lines of text on the right. Enter the following combination: R1, R2, R1 Left, Right, R1, Down, Down. The text will disappear then reappear, confirming the code. This will allow you to select from any of the unlockables on the following menu screen.
Jun 18, 2014 | Sony PlayStation Video Game Consoles &...
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
How do I load a Globe prepaid to my Champ Duos when after I send 223, the numeric disappears for me to be able to type in the card no.
Hi, To load value for Globe Prepaid:
  • Dial 223 and press Call (Green Key). Please follow the voice prompt.
  • Enter the Call & Text Card No. and press #.
  • Enter the Call & Text Card PIN and press #.
  • A voice prompt will then confirm that the reload attempt is successful.
I hope this helps.
Thanks for using FixYa.
Sep 13, 2011 | Cell Phones
Touch screen out of order
you should reset your mobile phone.if any touch screen is not functioning you can reset your phone.A pin hole is given near the usb port of phone for reset it.you can enter a needle into pinhole & press it slowly.after that your phone will reset.it take some moment. after it screen appers with text "align screen".taping the target until the "align screen" disappears.after disappearing align screen set which is given on the screen.after that windows will be installing.it take some moment.i hope your problem will be solved.
Dec 02, 2010 | i-mate JAM Pocket PC
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Red Arrow
The red arrow should represent a recent missed call. To get rid of it, press the left soft key when you are at the home (standby) screen to enter the calls menu. Press the return (arrow) key on your phone to return to the home screen and the arrow should have disappeared.
Nov 25, 2007 | Sony Ericsson Walkman® W880i Cellular...
Photo remains on screen, will not disappear without pressing "Menu" button
Is there a Reset option available Read the manual If this is not remedied by your action then get onto Casio Technical Support. If this is a young camera it may be replace able by Casio or they may advise you to return it to the seller. If it is an older camera - then it will be new camera time if you find the fault is not livable with
Jun 19, 2007 | Casio Exilim EX-Z750 Digital Camera
IMSI TurboCAD Full Version for Mac  Logo
95 people viewed this question
Top IMSI Computers & Internet Experts
Lesley Cameron
Lesley Cameron
Dan Shibata
Dan Shibata
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
