Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
The color is very orange but the black and white is fine blw_97@yahoo.com
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Computers & Internet
Need a radio wiring diagram for a 97 Nissan Altima i found one on line but it wasnt nothing like the colors of the wires in my car.
red = 12v ignition/acc
yellow= 12v battery/memory
black = ground
blue = power antenna
blue/white = amp turn on
black/white = amp ground
orange = illumination
orange/white = dimmer (+)
orange/black = dimmer (-)
brown = mute phone
speakers---
grey = right front positive
grey/black = right front negative
white = left front positive
white/black = left front negative
violet = right rear positive
violet/black = right rear negative
green = left rear positive
green/black = left rear negative
Dec 30, 2010 | Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
97 Ford Windstar audio wiring diagram
1997 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
hope this is the one your looking for pls rate
Apr 07, 2009 | 1997 Ford Windstar
1996/1997 Ford Windstar Audio wiring diagram
96 and 97 are the same
Apr 07, 2009 | 1997 Ford Expedition
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
1995 Chevy Blazer Wire Color Codes
95-97 blazer or 94-97 S-10
12volts red (there will be 2)+ ignition harness
Starter purple or yellow + ignition harness
Ignition pink + ignition harness
Second Ignition white or pink/white + ignition harness
Accessory orange + ignition harness
Power Lock lt. blue + either kick panel
Power Unlock white + either kick panel
Lock Motor gray drivers kick panel
Unlock Motor tan drivers kick panel
Parking Lights+ brown switch or rear harness
Door Trigger white - keyless module
Dome Supervision use door trigger
Trunk/Hatch Pin tied in with doors
Trunk/Hatch Release black/white + switch or keyless
Tachometer white AC ECM
Brake Wire white + at brake pedal switch
Parking Brake black at the pedal
Horn Trigger black - steering column
Jun 13, 2008 | 1995 Chevrolet Blazer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
20 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
