Question about Samsung SCH-u740 Cellular Phone
How do you enable the media player on the Samsung U740 double flip phone
The screen on my samsung double flip phone has gone white, what do I do to fix it?
I guess that is a Verizon Cellphone. It is most likely that the LCD has lost grip or contact from the main board or has gone bad . 1. You may disassemble it and check the LCD contact points on both the board and the screen...detatch attach it firmly or
2.You may have to replace the LCD completely.See what the LCD looks like here ....
http://cgi.ebay.com/OEM-SAMSUNG-ALIAS-SCH-U740-COMPLETE-REPLACEMENT-LCD-/370461654715?pt=PDA_Accessories&hash=item56413c3ebb#ht_500wt_689
I hope this helps you.
Good luck !
Mar 11, 2011 | Samsung SCH-u740 Cellular Phone
I need help converting my charging cable into a data cable to upload my photos that are on my samsung alias.
I don´t think your charging cable can be converted to a data cable. You can send your photos via bluetooth from your phone to a bluetooth enabled pc.
Sep 11, 2009 | Samsung SCH-u740 Cellular Phone
Samsung SCH-U740 Double-Flip will start to start up but loading bar never finishes it just freezes
Sounds like your problem could be a result of a MAJOR software trojan.
You start by taking the battery out, wait 30 seconds and replace battery. Turn on the device again to see if if will boot up correctly. (Note: If this does work it is merely a temporary fix)
I would check with your carrier/and or nearest store for service/repair options. Your device may need a software update or even a hard-reset to set device back to factory defaults.
Hope this helps! Thanks.
Mar 19, 2009 | Samsung SCH-u740 Cellular Phone
How to replace the flip.
Strongly suggest you go to Ebay and purchase a used on woth working screens in the end easier and cheeper. Plus you can hold yuor old phone for parts/back up.
Or sell as working wioth bronken front screen to help pay for the new phone.
This is what I did
Jan 04, 2009 | Samsung SCH-u740 Cellular Phone
Samsung sch-u740
take the phones to a professional mobile store and have them fix it for you
Sep 04, 2008 | Samsung SCH-u740 Cellular Phone
Can I use the phone as a mp3 player on an airplane with phone off?
Just put the phone in "Standalone Mode" and it should be fine.
May 21, 2008 | Samsung SCH-u740 Cellular Phone
Sync
go to vzam.net to dowload the latest software. you may also need windows media player 10. also you can only download unprotected files, meaning a lot of itunes for example wouldnt work.
Dec 05, 2007 | Samsung SCH-u740 Cellular Phone
Samsung u740 phone and itunes
Unfortunatly store reps have mostly only one thing in mind and that is to sell, sell, sell. Itunes uses a protect format called aac. which is unable to be played unless it is converted, the samsung alias (aka u740) does play MP3 format. My suggestion to you would be to use a program called Daniusoft Media Converter, to convert the music you have to mp3 and then transfer them to your phone via memory card or Verizons Music Essentials kit.
Nov 22, 2007 | Panasonic KX-TG5561VZCT VERIZON/CENTURYTEL...
U740 inside LCD cracked - need replacement directions
James121 is not correct. In this case, with the Samsun sch-u740, the screws are simple small philips screws. Its also pretty tough to get the cover off. you also have to deal with alot of wires to replace the lcd, including soldering the speaker back to the lcd. this is not recommended for 99% of people.
Oct 11, 2007 | Samsung SCH-u740 Cellular Phone
Transfering music from your computer to the phone
when you plug in the phone to the computer, go into menu- tools - mass storage- connect to computer and just look for the removable disk storage on " my computer" transfer all your music files to the media folder. hope this helps if you haven't gotten it to work
Sep 15, 2007 | Samsung SCH-u740 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
