Question about Brother MFC-8440 All-In-One Laser Printer
Paper Jam with MFC 8440, every time I print, or copy, it is getting jammed in the cartrige
The printer says there is a paper jam. I have
Try adjusting your paper tray. If you have the tray that adjusts from legal to letter it sometimes gets wiggled to some place inbetween. Just push it back into the letter position.
Apr 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Paper Jam
sometimes the paper gets jam internally if the small piece of paper is just not letting the gears to move fluently this problem cad occur.for resolving this the whole printer needs to be opened and cleaned part by part.
but sometimes unplugging the printer from the main power outlet for sometime the replugging it again resolves the problem.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Hello, I have Brother printer MFC 8440.I keep getting mesaage that i have paper jam. I checked all places and there is no paper jam.How can I fix that problem?
It's possible there is still a very small scrap of paper left. If you have a can of air blow it in and try to dislodge it. If that doesn't work try to unplug it wait a minute and plug back it.
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Not printing, says check original
Can be a document feeder jam.
Also can be that you are trying to copy an odd size original that it doesn't have the paper-stock for. in that printer it can be caused by not having the paper trays set correctly or using the menu to force it to try printing on something like legal size paper when it only has 8.5/11
Try resetting the printer with a power off and make sure the paper try is set to 8.5/11
Apr 24, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper Jam - now terribly noisy!
Fuser gear cracked from the sound of it or non oem or recycled toner cart that is too stiff to turn correctly
Dec 12, 2007 | Brother MFC-8440 All-In-One Laser Printer
Paper comes out plain
WAs the jam in drum?, check if carona on drum is intact (under the little slidy cleaning tab)
Nov 07, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
195 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
