Question about Hitachi 53UDX10B 53" Rear Projection Television
Double on picture
The picture shows up as double one in front one in back
  • Hitachi Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 13, 2009
  • Hitachi Master
  • 8,457 Answers
Ur Convergence is dead.U know how to solder?Buy the convergence kit use the parts and desolder and resoder repair.Tv Repair World.com to buy.
Posted on Sep 11, 2009
My jvc rear projection 48" tv is showing double images, what can I do to fix this problem
In the menu do the auto convergence. If still bad replace the convergence ics. Also check resistors around the ics. You can remove the front grill and access the conv board from the front. Small board on the right. It popps out.
Mar 25, 2010 | JVC AV-48WP74 48" Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Picture is in showing in double vision with colors serperated
bulb is going out. go back to where you bought it to see if warranty will cover it. if not, buy another bulb. ours was like, 40 bucks.
Apr 26, 2009 | Televison & Video
Screen showss double picture
Good Day, cs81801;
It sounds like the TV's Convergence Circuit has failed.First, try
to reset TV by unplugging TV from A/C source, for 2 to 5 minutes. Then plug TV back into outlet. Also, try the Magic Focus button on front of TV.
Still no work? To fix yourself call 1-800-458-6053 and ask for KIT 10. This will provide you with all the parts you will need. These are soldered in parts, or call an Authorized Service Center and have them give you a written estimate b4 repairs are performed. Cost? between $450 to 650 depending on your location and Service Center. Good Luck, big IRISH.
Sep 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Touch Focus Error
you need to replace both of the STK392-110 ICs you can get replacements at the following link and they come with free instalation instructions with pictures. Here's the link.
http://servicemanuals.vstore.ca/
Jun 20, 2008 | Toshiba 53H71 53 in. Rear Projection...
Double vision
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Toshiba 50A61 50" Rear Projection...
Double picture
your problem is in vertical section. 1 any capacitor in vertical section is defective. 2 transistors in output ckt might be defective 3 loose contact in vertical section. 4 problem in feed back circuit(if you are a technical person )
Sep 14, 2007 | Emerson EWF2704 TV
Bad Picture
You need to replace the convergence output IC's. I believe they are STK392-110's and there are ususally resistors that are opened due to faulty IC's. The IC's are located on a board behind the large speaker grill on front. There are 6 screws to remove to access the IC's. 4 in the back and 2 small screws behind the litte door on the front.
Feb 04, 2007 | JVC AV-56WP30 56" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
