Question about Kenmore Washing Machines
My washer has a error of f20 flashing on the screen what does this mean please help me
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
* If you have NO water in the wash tub, check the following:
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
Sep 24, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F20 error code
Hi.
F20 means that there is a water inlet problem:
Reasons for error F20:
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
If that does not help inlet valve, pressure switch and control module must be tested. The defective part must be replaced.
Here the tech sheet.
Regards.
Ginko
Aug 20, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
Code is F20, what does this mean?
Hi
Error F20 means Water Inlet Problem-no water or insufficient water supply. This issue can appear due to faulty inlet valves or due to blocked inlet hoses. Also check the filter screen at inlet valve, clean them if they are dirty. Select PAUSE/CANCEL twice to cancel the cycle. Unplug the washer or disconnect the power. Now check whether water faucets completely turned on? Make sure that the water inlet hoses are not frozen. If above things seems to be fine then you would need to replace the water inlet/fill valve.
Hope this helps... Please post back if you need more information. Daniel
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer keeps flashing F20
Hi
Daniel
Jan 23, 2011 | Washing Machines
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
You can please check the following -
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
