Question about Digital Research MagicVision DR-CM200 Webcam
I have a digital Research 32" LCD t.v. that I purchased 11/07. The problem is: Our television recently started to flicker, jitter, and or roll, at times completley dissappearing to a black screen. The sound is always there, it does not flicker or cut out. Our household is not an avid television watching family. We probably average, in a seven day week,10 to 15 hours of television a week. We did have the television connected to a surround sound system then from there we had the Comcast Cable box connected, as well as our d.v.d player connected to the surround sound. In fear that the surround sound was going out we disconnected it from the television and had the cable box wired directly to the television, still the picture flickered/rolled and or disappeared. We did the same thing with the d.v.d player and disconnected the cable box and only connected the d.v.d player, popped in a d.v.d and still the picture flickered/rolled and or dissappeared. It doesn't seem like we watch television enough for the unit to already be dead. Please let us know if there is something we are doing wrong with our configuring or if the unit needs service? Thanks, Kim Hipol
  • Digital Rese... Master
  • 16,195 Answers
The television has a bad component, have it serviced.
Posted on Mar 03, 2017
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
My TV has a severe flicker/jitter in the bottom left quadrant of the screen. How do I fix it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 27, 2017 | Samsung LN-T5271F 52 in. LCD Television
I have a Tevion 32 inch LCD (Model LCD3210id ), purchased from Aldi stores about 4 years ago. The screen has started flickering and it is making a slight crackling sound from the back. One, has anyon
Those sounds would be either your power converter/supply inside the TC or/and faulty cabling inside that has been worn out resulting in noises and flickering.
Dec 24, 2012 | Televison & Video
I have a SOYO-DYLT032B...32in LCD and I need a main module...not hopeful based on research...any clues?
what is the code for soyo tv 32" lcd to activate my digital remote to use it for all functions instead of using two remotes one to turn off and on and the other to navigate.
Nov 07, 2009 | Soyo DYLT032D 32 in. LCD Television
Samsung 32" LCD tv, No picture with audio
i will first resolder all ic`s and connections,especiall on the crt board,clean around the flyback at the abl circuits,check for open or changed valued resisters in abl circuit and the video b+ on the crt board (usually 165-200 volts) check also the screen voltage (G2) volts,should be around 250 - 400 volts.
Sep 18, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
Jumpy screen as a monitor
There are a number of things that can cause the problem:
The frame and scan rate from your computer is not matched to the specs of the monitor. The monitor may have a sync lock fault.
LCD monitors must be operated in their native mode for best results. Some models are very critical for the frame and scan rate especialy when using a composite video source.
If you take the monitor to the service rep for it, the should be equiped to diagnose it and tell you the exact answer.
Jerry G.
Apr 07, 2008 | iLO 3200 32 in. LCD Television
Flashing screen when ps2 or dvd player is plugged into my LCD 3201C
I had the same problem!
This TV does not go down to a 480 resolution! If I know that, I would of never bought this TV. I cant use my VHS, PS2, Nintendo (Original). So now I'm trying to save money to get a 120Hz HDTV :P
Feb 23, 2008 | Dell W3201C 32 in. LCD Television
Digital Research MagicVision DR-CM200 Webcam Logo
51 people viewed this question
Top Digital Research Computers & Internet Experts
David Payne
David Payne
Are you a Digital Research Computer and Internet Expert? Answer questions, earn points and help others
