Question about LG Neon GT365 Cell Phone
Speaker broke ringtones and alarms do not work, sound doesn't work but vibrate does. VERY livid!!! help anyone...?
  • 3 Answers
Try restarting ur phone...or remove the battery nd put it bak in.....
Posted on Sep 11, 2009
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    My HTC legend will not vibrate or play ringtone on incoming calls. The screen lights up as it should when the phone is being called, but no sound or vibrations are being produced. I've played around...
    First back up you phone on to your computer or one of the cloud services. Go to the Google Play store and search for backup and find a backup service that you would like and perform a factory reset on your phone if this doesn't work then your speaker is not working and then you might as well replace it.
    Sep 03, 2012 | Cell Phones
    Samsung wave no message sound
    I have seen this one or two times with a few of my Samsungs but the only way I have found to fix it is to power off the phone and power it back on. If that doesn't work you might try going through the phone settings and un-checking/rechecking and sliding all possible sound options to make sure nothing is coincidentally set for this.
    Mar 28, 2012 | Samsung Wave S8500 Smartphone
    The sound does not work on my samsung infuse 4g. I press the volume buttons up and down. I can't hear the ringer on any incoming calls. The alarm clock doesn't sound. I can hear it if I have my...
    I had the same issue. Its hardware related due to no good contact between the phone and your tiny speaker.
    To fix it no too hard.
    1) Open up your Samsung infuse case directions here video http://www.youtube.com/watch?v=ewdyo2fkJj8
    or pictures http://androidforums.com/samsung-infuse-4g/532693-how-fix-samsung-infuse-4g-screen.html
    2) The speaker is located bottom left corner (two etched holes for sound)
    3) With cover off locate 2 brass/bronze tabs that connect the phone to the speaker.
    4) Slightly lift these tabs make sure not to far to brake off (1 mm)
    5) Put back the cover and phone speaker should work fine
    I hope this helps.
    Jul 13, 2011 | Cell Phones
    LG env3 alarm clock vibrate
    Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
    Oct 20, 2009 | LG enV3 VX9200 Cell Phone
    HTC Touch Diamond will vibrate, but won't ring on incoming calls
    I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
    Aug 02, 2009 | HTC Touch Diamond Smartphone
    No sounds for alarm texts calls or windows media
    Mine did that and I just changed to profile and changed it back to normal and it worked. I hope it helps
    Jul 21, 2009 | Motorola Mobility Moto Q
    Motorola Adventure 750 phone-- no speaker sound. Why?
    You've probably already tried these, but what the heck; you asked...
    1) Check in MENU -> SETTINGS & TOOLS -> SOUND SETTINGS -> CALL SOUNDS -> CALL RINGTONE to make sure that you have actually selected a ringtone instead of the "No Ring" option at the bottom.
    2) With the phone open, try the up/down buttons on the left-hand side of the phone (above the Push-To-Talk button) to make sure that your volume isn't set to "All Sounds Off," "Alarm Only," or "Vibrate Only." It has to be at least at "Low" before a ringtone will play.
    Hope this helps. If not, you probably need to take it in to a Verizon store for an expert assessment; they'll usually take a look at your phone and install any software updates for free.
    Mar 10, 2009 | Motorola Mobility V750 Cellular Phone
    Motorola Razr V3 speaker doesn't work
    The speaker needs to be replaced.THE SPEAKER is located in the bottom section of the phone. You;ll have to remaove the bottom section with a t6 screwdriverand replace the speaker in this section. Sam!
    Jun 17, 2007 | Motorola Mobility RAZR V3
    LG Neon GT365  Cell Phone Logo
    146 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
