Question about Panasonic KX-TG5583 Trio Cordless Phone
We have a Panasonic KX-TG5583 Phone system. The phone itself works fine, but the answering machine says "memory full" and won't accept any more messages, even though it says there are no messages.
  • 193 Answers
SOURCE: Callers can't hear me but I can hear them
change the channels on the phone and reboot it
Posted on Oct 09, 2007
SOURCE: Panasonic KX-A144ES
Press Int then # then *5
Posted on Dec 16, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
    I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
    Posted on Jun 05, 2010
    HOW DO I CHANGE ANSWERING MACHINE MESSAGEV ON PANASONIC KX-TGA642C PHONE
    The KX-TGA642C is a handset for the KX-TG6421 series phone system. (These are sold as the KX-TG6422 or KX-TG6424, depending on the number of handsets in the initial package.) To record a greeting message, make sure that the phone (all handsets) is in standby. Then press Menu on a handset. Press # 3 0 2 (or use the Up/Down arrow keys to navigate to Ans Device > Greeting > Record Message. Press Select to each menu/sub-menu section.) Highlight Yes and press Select. After you hear the beep, speak your message clearly. Press Stop to end the recording. (The maximum greeting length is 2 minutes.) Press Off to exit the Menu system. If the answering system is on, this message should play.
    The manual for the KX-TG6422 has the full directions to change the answering machine message. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/KXTG6411-12-13-14-OI-Eng.pdf . See page 33 for the directions.
    I hope this helps.
    Jul 03, 2016 | Panasonic Lands Phones
    My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
    ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
    Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
    I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
    It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
    In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
    Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
    Hi how do i connect panasonic kx t7731 phone to kx tm 100b answering mcchine. i do not know what system i have and i connected as manual and it is not working. thanks
    That's because whatever system it's connected to, it either has to be in the port by itself, or you have to BRIDGE the answering machine in system programming. You pick.
    If it's a port on a TA series, you can tell the system there's an answering machine on it and it will let you override the incoming playback and pick a call from the line.
    Carl
    Aug 18, 2011 | Panasonic KX-T7731 Corded Phone
    Our Panasonic KX-T7630 phone system does not have voice mail built in. What sort of answer machine should I purchase to use with it?
    Any digital answering machine will work just fine for you. These days you won't be able to find any of them made with tapes. You could also check with your phone company provider about voicemail service.
    Apr 21, 2011 | Panasonic KX-T7630 Corded Phone
    My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
    The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
    To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
    If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
    The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
    I hope this helps.
    Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
    RE: Model #kx-tga931t telephone Panasonic brand
    Press: menu scroll down to talking caller id press select scroll down once till you see "off" press select You have to do this on each handset
    Dec 21, 2008 | Panasonic KX-TG5583 Trio Cordless Phone
    I Need Help
    hi sir
    go to the settings>
    advanced settings>
    answer machine > enable.
    it work's thank u. sir
    Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
    Oct 09, 2007 | Panasonic KX-TG6021 Cordless Phone
    Panasonic KX-TG5583 Trio Cordless Phone Logo
    88 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
