Question about Samsung SYNC SGH-A707 Cellular Phone
Studio v3 connection failure
Keep getting TCP_IP CP error 718 when trying to connect to network via Sync......what's this mean?
  • ccattnurse Dec 12, 2007
    I have A new 707 Sync. I purchased a utility/connectivity cd. when I put the new driver cd in the computer, I get an alert telling me that I must install Shockwave Player 8.5. I click on the link to install the player. It installs properly, however I cstill cannot install the drivers because it still indicates that the player needs to be installed. I have repeated this several times with restarts as well. The version that Adobe installs at the link is a newer version than that which the error indicates that I require. Could that be a problem?
  • dmcc98 Feb 07, 2008
    Turned out that the error was pretty inconsistent and I'm pretty sure it was somehow related to whether the local AT&T tower was enabled for data connections or not.....at least, that was my guess as, if I waited for awhile, I was able to connect just fine. Technology........unreliable as always.
    Problem Solver:
  • 12 Answers
This means insufficiant balance or network problems which can even means that u r not connected to gprs
Posted on Feb 07, 2008
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
I keep getting kicked off during online play (8002AD23). I have a wired, ethernet connection
That error means your PS3 is having trouble connecting to the PS Network. That can be caused either by your internet speed (if you are downloading something for example, it may lower your speed and cause this error) or by a random glitch on the PSN. You should also try forwarding the ports from your router. The PS3 required ports are : TCP 80 TCP 443 TCP 5223 UDP 3478 UDP 3479 UDP 3658
Also keep in mind that it is recommended you set your PS3 to use a Static IP. I hope that helps
Philip
May 27, 2011 | Sony Playstation 3 (PS3) Console
One of my computers wont connect to internet keeps saying limited acsess other computers are working fine
It means there is issue of tcp ip address. Limited connectivity means network adapter tcp ip not correct or not getting ip from DHCP server. For that set static ip in network adapter tcp ip property ac your local network range. Let me know if you need further assistance. Thanks for using FixYa.
May 25, 2011 | Computers & Internet
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
Tcp error on connection in internet
tcp error means there is something wrong with TCP/IP PROTOCOL, with is basic network service. try restarting services. if it won't work there may be something wrong with DNS server
Oct 05, 2009 | Microsoft Computers & Internet
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
I have a zyxel p66ohw router connected to my pc via an ethernet card, everything is fine untill my son logs on with his playstation 3, or my wife logs on with her laptop then i cant connect everytime i try...
Make sure that your TCP/IP properties are set to "Obtain an IP address automatically". If you still cannot connect after you change that, and after waiting for a couple of minutes, then open a command prompt and type "IPCONFIG". Make a note of the address at "Default Gateway . . . . . . . . . :" That's the address you need to go to to access the modem's settings..You'll need an ID and password. These would be in the modem's manual.
---to find tcp/ip properties---
It depends from PC to PC, but, try this:
Start (Bottom left of your screen)
Settings
Network Connections
Local Area Connection
Properties
Internet Protocol TCP/IP
Properties
That's how it is on my PC.
Oct 10, 2008 | Computers & Internet
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Samsung SYNC SGH-A707 Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
