I've got an air conditioner (Carrier 38TKB) that keeps blowing fuses (Bussmann FRN-R-50). It runs great after installing a new set of fuses but after a couple of hours it quits all together.
  • davmalk Sep 14, 2009
    Yes the fuses are rather loose in the holder. I never thought that, that would be the problem. Thank you I really appreciate your timely response.
  • 1,218 Answers
In almost every case that I've dealt with concerned repeated blown fuses, if you can not find a short, it is usually the fuse holder itself. If the fuse is not VERY TIGHT in it's holder, it heats up and then blows. It is not always an over amping problem that blows the fuse. Check it out. Next time, see if the fuse is extremely hot. DON't GET SHOCKED! KILL POWER FIRST!
Posted on Sep 12, 2009
2003 carrier weathermaker 38tkb unit 40,000 btus 10.5 seer 3.5 ton - what should start amperage be?? is 132 too high tks
as you are running 2.5 or 3 mm wire for the unit , at 132 amps the wire would melt
check the setting of the amp meter as it is more like 13.2 amps which would be about right
use an example , check the size of the wires from a battery in a car and that size wire carries 400 amps minimum when starting a car, then check the wire size to the unit
all compressors start with a high current draw ( 25 amps ) but it drops of to running current after a 1/2 second or so
May 24, 2016 | Carrier Heating & Cooling
Carrier 52CE set on high heat; blows cool air
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Carrier 52CE-309 Cool Electric Heat Air...
I need to know where the little fuse like thing is on the carrier air unit. Everything works but blows hot air. Had this problem before but do not where fuse is at.
The fuses you need to check are in a box by the outside unit... the wires from that box run into the outside unit to give it power...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Carrier Heating & Cooling
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Fan circuit board on a/c is blowing
You have a short somewhere in your system. It could be anything from a thermostat, thermostat wire or any component in your system. Honestly, you are better off calling a tech.
Feb 22, 2008 | Carrier 52FE312-3 Air Conditioner
Heating & Cooling Logo
452 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
