Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Used to make several batches of ice a day, now 1-2 a week.
We have tried to have the control board on the ice maker itself replace that did not fit. I also changed the valve assembly. Still not fixed. Would it be in the board that is behind the buttons on the door? Looks like ther are two boards there, one power, and the other control. Since the water and ice dispenser seems to work fine and there are lights on the buttons, it sounds more like a control problem. How much does this board have to do with the ice maker?
  • kwillbanks Sep 14, 2009
    I just last week got the ice maker back and reinstalled it again. The repair guy says it has worked in both other freezers he has tried it in. Right now it seems to be making full cubes just not at the rate it used to. I now get 1 batch every 4 hrs, it used to make one in just about a hour. We never ran out of ice before, now it happens often.
  • 93 Answers
If your refrig has the icebucket on the door and the icemaker on the roof of the fridge then you have two eyes on each side of the freezer....they are bad. If not then the icemaker module is bad. If you have a regular icemaker that hangs from the left side of the freezer then the module is bad. Also......Is your freezer still working good? Icemakers will not work if the temp is not low enough. Are you sure the icemaker is cycling but not making the full number of cubes? Low water pressure will force the icemaker to make only a few cubes at a time
Posted on Sep 12, 2009
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
How to make ice faster
Good day,
When an ice maker harvests a batch, the next batch will be determined by a thermostat embedded in the ice maker body.
When it resets the next harvest will occur, thus determining the frequency of harvest cycles. Thus production.
The first thing to determine is the size of the cubes. If they have become slowly undersized, it could be the water valve's diaphragm starting to swell. If that is the case, then replacing the valve is the only solution. It cannot be serviced.
The second thing is the water feed from the house. The line, and even more so the fittings can start to corrode, slowing the water flow down, producing the same effect described above.
If it has a water filter, that as well can cause this same issue.
Lastly, the temperature of the freezer has a major effect on production. You should check the freezer temperature with an accurate thermometer. It should be at, or very close to zero.
Any temperature above that will slow production.
Although rare, the thermostat in the ice maker can go out of calibration causing slow cycles. Impossible to test, it is one of your last options.
I am assuming the water pressure in the house is normal. Houses with low water pressure can have severe low ice production.
Sep 18, 2010 | Sub-Zero Bottom Freezer Refrigerator
I HAVE A WHIRLPOOL THAT I BROUGHT FROM A LADY IT IS A SIDE BY SIDE STAINELESS STEEL GOLD DESIGN FIT THE ICE MAKER JUST STOP WORKING NOT SURE IF THERE IS AND OFF ON BUTTON
Add some water to the ice maker. If it makes a batch replace the water valve. If it does not then replace the ice maker.
Mar 12, 2010 | Refrigerators
Ice frozen over in ice maker, makes a clicking sound, the on off lever was obstructed and I think the tray did not empty the last cycle and more water flowed over the tray, how do I get it to empty?
Good day,
It won't empty itself, you have to remove the ice maker, and let it defrost and melt itself. Do not rush it. In fact leave it out overnight,
Re-install it, and check for performance. may take up to 6 hours for the first batch.
If it overflows, then the water valve in the back rear of the machine needs to be replaced. It's not opening and closing properly.
If the ice maker does not function, then it must be replaced, and it's smart to install a new valve at the same time.
Thank you for using FixYa
Jan 08, 2010 | Maytag MSD2454G Side by Side Refrigerator
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
Jun 16, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
