Question about Brother HL-4070CDW Printer
BRother HL-cdw4070 Printer Error message
I replaced all 3 color toner cartridges, but the printer keeps telling me the yellow cartridge needs to be replaced. It doesn't want to recognize the new cartridge. Any ideas?
HL-2280DW says replace toner but I already have
Just do a manual reset:-
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Original Brother tonor cartidges should reset automatically.
Apr 17, 2014 | Brother HL2280DW: HL-2280DW Wireless Laser...
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
How to remove the cartridge on Brother HP1440 printer
Hi seevram,
Follow the procedure below to remove and replace toner cartridges for your Brother HP1440 printer:
1. First, open the Front Cover of the printer.
2. Remove the Toner Cartridge(s) that has run out of toner. Pull the Toner Cartridge out slightly with one hand, then hold the Toner Cartridge with both hands and pull it out of the printer.
3.
After rocking each new Toner Cartridge 3 to 4 times from side to side, remove the tape labeled 'REMOVE' and the orange protective cover from the new Toner Cartridge.
4. Then,
insert the new Toner Cartridge(s) by positioning it in the correct guide(s). Slide it gently into the printer.
Reminder:
  • Do not try to lock or push it in; it should rest loosely in the guide rails.
  • Each color cartridge is individually keyed to prevent improper installation. Match each cartridge color label to the corresponding label on the printer.
5. Finally, close the Front Cover.
Also, I have included here a link where you can download a service manual for your Brother HP1440. Kindly click here.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother HL 1440 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Nov 10, 2009 | Brother HL-4040CN Laser Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Brother HL-4070CDW Printer Logo
231 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
