Question about Toshiba Computers & Internet
Satellite A215-S7444 laptop's fan is no longer working. Was working earlier. What do I do to fix it?
  • artistorwitc Sep 11, 2009
    Thank you for the quick response! I have another question though... if I do need to replace the fan, do you know where I might get one or anything like that?
    Also, I'd prefer to try and put the new one in myself... do you know of anywhere that has detailed instructions so that I might do this?
    You're describing exactly what happened with my laptop! Thank you so, so much for your response!
    Alright, thank you so much, you've been a wonderful help, I truly, truly appreciate it!
  • Toshiba Master
  • 32,281 Answers
If the fan was making a bearing noise and has stopped spinning then the fan needs to be replaced.
The fan may have stopped spinning because it is clogged with dust, if so loosen with a still brush and vacuum to remove the dust.
A faulty fan will cause the CPU to overheat and shutdown the computer and will not start up again until it has cooled down. Continue to ignore this it will eventually cause the CPU to fail.
Posted on Sep 11, 2009
  • Chris Hingee
    Chris Hingee Sep 11, 2009
    You might be able to get a replacement from Toshiba. Alternately I would remove the fan and take it to an electronic hobby shop or computer shop and purchase one the same size (check the label on the fan, - most likely 5V DC three wires). The only problem would be the plug on the fan, just cut off the connector with sufficient cable length and solder the connector onto the new fan. Put heatshrink tubing around the soldered wires to prevent the wires shorting against each other.
    Not sure how to remove the fan on your model Toshiba, if there is a round vent on the bottom of the laptop, then the fah may be behind this panel. If the rectangular vent/s are on the sides or back of the laptop then the fan and heatsink assembly is under the keyboard. Remove the keyboard to gain access to the fan and heatsink. This assembly will be held by spring loaded screws over the CPU. The fan will be screwed to the heatsink. When you reinstall the fan and heatsink assembly don't forget to apply fresh thermal paste to the heatsink before you attach it to the CPU.
Toshiba satellite a215-s7444 password
Reset toshia windows password,three methods for you.
Method 1: Unlock Windows login password with Windows password reset disk.
Method 2: Unlock Windows password with Windows built-in Administrator account.
Method3: Unlock Windows password with commercial and professional Windows password reset tool.
Details in http://www.windowspasswordreset.net/article/unlock-windows-password.html
Jul 18, 2012 | Toshiba Satellite A215-S7444 Notebook
I have a toshiba sattelite a215-s7444 and lost the adminastrator password to get on my laptop is there any way to bypass my old password I tried to burn a usb reset key but it wont work thanks
If it's the BIOS password then no, only a Toshiba dealer can reset it. If it's a Windows password then use this
http://pogostick.net/~pnh/ntpasswd/
Aug 18, 2011 | Toshiba Satellite A215-S7444 Notebook
WHEN I TURN ON MY LABTOP WHAT I SEE IS ENTER PASSWORD (BIOS).SATELITE A215-S7444
if you forgot password remove mainboard battery for 5 min will clear all passwords
Feb 02, 2011 | Toshiba Satellite A215-S7462 Laptop
Toshiba a215 s7444 high pitched noise
If the high pitch noise is coming from the bottom edge of the LCD screen, then the noise could be coming from the inverter.
Replacement inverters are available from :-
www.lcdparts.net
Nov 03, 2010 | Toshiba Satellite A215-S7444 Notebook
I have a previously owned Toshiba A215 S7444 Satellite Laptop, when booting up I get a black screen and it asks for the Phoenix Bios Password. The previous owner does not know the password and it is NOT...
You can either find the CMOS backup battery and take it out for a while to let the memory discharge, or look online to find a program which will crack the Phoenix password (these do exist, I had to use them when I was in business fixing computers).
Apr 17, 2010 | Toshiba Satellite A215-S7444 Notebook
How to reset Toshiba A215 S7444 bios password?
Contact Toshiba Support, If you are the Original or Registered owner of that system, they can help u. They have the "Master Password"
Apr 13, 2010 | Toshiba Satellite A215-S7444 Notebook
LOPTOP CAMERA DOSE NAOT WOREK
check for the drivers first in device manager
Nov 28, 2008 | Computers & Internet
Insert Button not working
are you using the Alt key first on Insert? Word is a keystroke monster, and won't recognize it without that keystroke. Got Backup?
Feb 10, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
617 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
