Question about JVC Everio Share Station DVD Burner Burner
Will not recognize disk
Treds the reccommended disks wont accept
    Problem Solver:
  • 17 Answers
Try using DVD-R 4X or 8X or 16X any brand with this rating should work, since i had similar problems and these work for me now.
Posted on Sep 11, 2009
My cd burner does not recognize a blank disk to burn. It keeps asking me to insert a blank disk even though I had just put a new blank disc in.
Are you putting the type of CD's it accepts?
Many burners will only accept specific disk types, such as most won't accept RW. That could be the possible issue in this case, what kind of burner are you using? If you post the model I could tell you what kind of disks it accepts.
Feb 24, 2013 | Hitachi Deskstar 7K80 HDS728080PLA380 80GB...
Baby lock ellure plus
Can you elaboate more on the issue
Apr 06, 2008 | Baby Lock Ellure
My computer wont recognize my external hard drve and the io magic light is blinking
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Jun 24, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Wont recognize burned disk
Is the burned disk recognized in some other computer?
Is any "official" (purchased music CD, or purchased DVD video, or purchased Microsoft software) disk recognized when inserted into the device?
If you burn a disk on your computer, can your computer then read that burned disk?
May 29, 2010 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Xo vision dvd player/receiver 1906 wont read my usb or SD disk.
Consult the manual, it should probably say something about external media.
Check what kind of disk format is supported by your player - some players will recognize an external usb disk (or a usb memory stick) only if it's formatted in FAT32 file system.
Note that if you format the disk on a Windows machine, it will only do it on drives with a relatively small capacity (i think it's up to 32 GigaBytes), but other operating systems (like MAC OS) can perform a FAT32 format even on drives with far greater capacity.
As for the SD disk (did you mean a SD memory card?), see what the manual says about the format type, have the card (disk) formatted in the supported format and see if that works, otherwise you might want to try other brands of SD cards - my friend has an Avia (not Aiwa) dvd player with a usb port and a SD card slot and it simply won't accept some brands or models of SD cards, but will work well with others and it also works well with USB disks and USB memory sticks formatted in FAT32 file system.
That's about all i could suggest, i hope you can get it to work.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
My ps3 wont take the disk!!!! HELP ME!!!!!!
if you take the system apart, check the blu ray optical sensor. its the really small board on the top front of the BluRay player. if it is positioned wrong it wont accept disks correctly. its worth a shot, and a easy fix. if you dont want to try that , i would suggest sending it to sony or selling it.
Jul 19, 2009 | Sony PlayStation® 3 (80GB) Console
Wont recognize a disk
The lazer or the chip on the drive control board are faulty,give sony a call,their support line is very good,they may even replace your console even if its out of warranty(they did for me).
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
My ps2 slim wont recognize any disks
1 ) First did u try other disk beside that one if yes and same no respone
2 ) Then try using disk cleaner with anti static liquid
3 ) Let it run about 10 minite
4 ) Try the disk games if no respone
5 ) Open your ps2 and make some cleaning but do not ever touch the lens
6 ) After that try back the games if not respone try
7 ) Listen to the disk spining or not if no mean the spinner broken or part in ps2 mean cost a money if yes i think your lens must be replace
Dec 01, 2008 | Sony PlayStation 2 Slimline Console
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Wont recognize burned disks
This does sound like a defective drive, most likely a laser / reader issue, because the refractive properties of the CDR is different from a "pressed" disk it looks like thia failed TOC seek issue, the head starts at the center of the disk and reads outwards, the click noise is most likeley the head reaching the terminus (the outer limit of the motorised movement), the drive then unable to find the TOC gives up and decides the disk is unreadable. if this drive is within the manufacturer's Warrantee period I would reccommend sending it back.
Apr 25, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
JVC Everio Share Station DVD Burner Burner Logo
48 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
