Question about Canon PIXMA MP830 All-In-One InkJet Printer
When printing in colour - prints are apearing striped. Have cleaned heads. OK when using 'greyscale printing'
    President:
  • 2,030 Answers
You are either low on ink, need new print heads/cartridges, or simplt need to keep cleaning it
Posted on Sep 11, 2009
Can i only print in black and white on my pixma mp250?
First you need to check your printer preferences/settings and check "Greyscale" printing box is unchecked (no tick or cross) if so then its a printer problem.
I'm guessing it has 2 cartridges, on colour and one black. As a guess the colour print head has become blocked. You can try clearing it with the printer clean functions, but this invariably just wastes your ink. You need to get a print head cleaning kit. PC shops or ebay.
Sep 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Can i set the printer to print black only
Hi ethelinebake.
I thing the right way to ask would be..Can i print without colour, and the answer is, yes in Greyscale
I am from Denmark, mayby some of text and pictures not look simular to yours, but i think you can see what i mean - ok
Go to controlpanel ->Printers (or Printers and fax), right cklick on your printer -> click on "Print Preferences"(see pricture Fig. 1 ("Udskriftsindstillinger" = "Print Preferences"))
Now you get a new menu, cklick on "Adwanced" (see picture Fig. 2 ("Avanceret" = "Advanced")), then select "Greyscale" ("Gr?skala" = "Greyscale"), and then "OK".
All what i printed out after that, was in greyscale "colour".
...now you also have learnd a little bit danish too :o))
Oct 11, 2010 | Brother DCP-330C All-In-One InkJet Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Printing quality suddenly deteriorated
You could have printhead problems but I would offer that you do a deep clean and consider replacing cartridges with OEM
Nov 13, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
IP3300 Problem with greyscale photo prints
Have you tried configuring the paper options for the type of paper you are using?
Oct 08, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
No Colour - everything in greyscale
just go to printing preference set to color and not to grayscale
Apr 20, 2008 | HP Deskjet 2360 InkJet Printer
Print black & white?
Your printer will keep using the color cartridges to keep the printing head working even if you don't print in color. If you need to print only in greyscale, buy a cheap HP printer (Printer only, not a PSC) and remove the color cartridge.
Apr 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
