Question about Compaq (283983-001) Motherboard
I just asked about removein the startup password wat do mean with the jumper i am new with computers so could u explain a lil more
  • 164 Answers
i just asked about removein the startup password - 3ac542afbc4ff40fe47b72448dec8cca.png they look like this and can be any color... Most motherboards can have the BIOS password reset by moving the jumper to the correct pin position. Many motherboards have small print by the jumper to indicate the correct positions. For example you might see some pins on the mother board, with a jumper like the one above, with the words PSWD RST or something similar wrote on the mother board. If the jumper is on pins 1 and 2 move it over to pins 2 and 3, then reboot your computer. Then shut down the computer down and put the jumper back where it was and it should have reset the pass word.
I would advise you to compare my instructions to that of *********** boards manual which you can download form the mother boards manufacturers website.
Posted on Sep 11, 2009
    Brigadier General:
  • 10,406 Answers
If the desktop (not laptop) computer asks for a password as soon as you turn it on, there is a password.
Turn the computer off. Unplug the power-cable.
Look very carefully on the motherboard,
for 3 gold pins in a row, and a "jumper" that connectors the center pin
with one of the "end" pins.
Look on the motherboard for silk-screened text,
such as "CLEAR BIOS".
Move the jumper from "1-to-2" to "2-to-3".
Wait 2 seconds.
Move the jumper back to its original position.
Add power.,
Start your computer.
Voila! No password.
Testimonial: "even more help thanks"
    President:
  • 392 Answers
Jumper is a chip, that acts like a switch, if u want to connect one positive side with negative side, we use jumper. U can find it back side of CD-ROM drive, Hard Disk Drive and on motherboards also. Remove in password is that the BIOS password , if u forgot that password , u can reset by removing the jumper or CMOS battery for 3 minutes and replacing it again.
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
Reset motherboard bios
remove the bios battery for arounf 30 minutes to an hour. if you can locte the bios jumper, just turn the PC on the , unplug the jumper then the pc off, put the jumper back and you are good to go on the next reboot.
Aug 10, 2008 | Intel D865GLCLK Motherboard
Hello, I recently had a Toshiba Sattelite L455 that suddenly promped for a BIOS password on startup. There was never a bios password set for this laptop. So I found a workaround using the onboard...
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Jul 24, 2011 | Toshiba Satellite L455S5980 Notebook
I have a Gateway computer running Win98 that prompts me for a password at startup. It didn't use to do this, so I don't know what password it is asking for. Never used one! It is doing this after a power...
Somehow, the motherboard thinks that a "start-up" password is required.
If you have a desktop computer, turn the computer off, open the case, and look on the motherboard. Look for three pins (labelled 1, 2, and 3), and look for a small "jumper" that is connecting pin 1 to pin 2. Move the jumper to connect pin 2 to pin 3. Wait 5 seconds.
Move the jumper back to connect pin 1 to pin 2.
Turn the computer on -- the "BIOS-password" will have been removed.
Jul 17, 2010 | Gateway (4000484) Motherboard
My son set a password on a Dell computer and does not remember what it is. Is there a way I can bypass this and reset the password. It asks for a password on start up and has windows xp.
You can definitely reset the password for your computer just do the ff steps:
  • when the computer is starting up press F8 simultaneously
  • select safeboot when prompted for boot options
  • login as administrator
  • when you are on the main screen click start
  • select control panel
  • select USERS
  • select the username that you are using
  • click on remove password
  • then restart your computer
Hope this will help
Thanks
Byron
Sep 24, 2009 | Dell Computers & Internet
Ok i dont have a clue wat u mean by fixin th jumper on the board i am new with workin on computers so if u could explain more i would be greatful email at forgottonson666@aol.com
Look on the motherboard.
Look for gold-colour pins, sticking at 90 degrees to the motherboard.
Some of those pins may be arranged in a 2-by-N "grid".
Some of those pins may have a (usually black-coloured) jumper,
which electrically connects two pins.
Move the jumper to the desired pair of pins.
Sep 11, 2009 | Computers & Internet
Forgot password
On the Thinkpad's, it's a fairly easy process to reset the passwords. Try the following steps and you should be able to access the computer...
1. Power off the lpatop.
2. Flip the laptop over and open the Memory cover. It should have the diagram of a Dimm on it.
3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
4. Remove the jumper, or whatever you used to short the password pads and put the cover back on the bottom of the laptop.
5. Power on the laptop and you should be fine.
Kerry L
Apr 07, 2009 | IBM ThinkPad T21 2648 Notebook
Computer locked
There are 2 types of lock i know
1) computer lock at dos asking for password to boot up
reset cmos will do the job
remove power plug and off all power
remove tower side cover
look for a 3 pin or 2 pin cmos jumper and short circuit it.
remove motherboard battery
wait like 5 minutes
fix everything back and your done
2) computer is asking for password at windows login screen
for this problem see if you can login to guest account
then go start
then run
type cmd
type net users [] *
enter the new password
enter the new password again
note
[] means the account name
the password you type will not apper on the screen .
Jan 29, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Powers down at startup
IF YOU TALK ABOUT A NOTEBOOK AND THE BIOS PASSWORD, CONTINUE READING THIS, otherwise if you are talking about operative system pass or PC... please let me know what os are you using to tell you explain that.
It seems that someone else has tryed to use your computer... what you should do is the following. Firs of all, some notebooks have a little well hidden button to reset BIOS, you notebook manual should tell you so, if not you should disassemble your notebook, so you will need very much help... I can guide you but first I must know if I understood you.
If you have a PC and its the bios password you are talking about, just open the case, remove all cables and let the case alone, take the lithium battery out for 30 minutes and start the system again, the bios will be in zero point so no password will be asked... Mother also has a jumper that resets the bios if you change its possition for a couple of minutes... you can see that in the manual (that jumper is called CMOS jumper).
If your problem is Windows or any OS password there are some things you can do, but please let me know first to guide you well.
Mar 07, 2008 | Dell Pentium 4, 2.26 GHz (1W391)
Compaq (283983-001) Motherboard Logo
197 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
