Question about Apple iMac G5 Desktop
IMac freezes on startup. Can't use safemode.
My iMac freezes on startup. I can't use safemode. The sleep light turns on. The fan and cd drive turn on as well. The screen stays black though. Once it got to the spinning icon that you see before the "OS is starting up" dialogue. Then it froze. When I had it on last it suddenly went unresponsive and a message pooped up that said something like. "Your computer needs to restart. hold down the power button to turn off." It had translations in 3 other languages (french, chinese, and spanish.I think).I couldn't do anything but do what it said. It froze the next time I turned it on. I can't turn it on in safemode.
    Novelist:
  • 85 Answers
Safe mode just requires holding shift down during start up and if it starts up at all this should be possible. Once in safe mode, you should be able to use Disk Utility to Verify disk and Fix Permissions. To Repair disk or with/without safe mode you need to startup with your install disk and on the first screen or after selecting language, use options to select Disk Utility. You really should tell us the MacOS version--10.3.9 10.4.11 10.5.8 or 10.6 are current and tell us your install disk version, too. With safe mode you can use terminal to run fsck to fix the disk, read the man page. Alternatives include starting up in Target Disk Mode (command+t at startup) and using your computer as an external disk for another Mac by Firewire or possibly USB, fixing it using the others software. These methods in descending ease.
A now permanently dark screen would indicate a bigger problem and a trip to an Apple store for an evaluation. Tell us your iMac model--could affect whether you can easily savage your disk data in this case. -Ken
Posted on Sep 11, 2009
  • ddp54 Dec 28, 2011
    Im using a windows keybord can't seem to enter safemode would not startup after os update latest just get apple icon and spinning icon
  • Kenneth Klare
    Kenneth Klare Dec 28, 2011
    This was 3 years ago. IIRC, taking the back off, I found the LED sequence would not go on. The CPU was just bad. I had the option of having Apple look at it and replace something for over $800. I chose to buy a new Apple Intel MacBook for over $1000--the early 2009 white MacBook. I have since upgraded the memory to the max 4GB and the drive to 500 GB and that to a 128 GB SSD. I love it. The great thing about this MacBook is it has a replaceable battery (soon to be needed), easy access to upgrade the memory and drive from the battery compartment--try that with later models. It had the mini-HDMI, since superceded by the Display Port and now by Thunderbolt but it does full HDMI although sound would need the separate TOSlink. Just as well out of G5 as that dead-ended--no going back.-Ken
My Imac A1058 won't start up only the fans work
Never heard of before, though power there.
Guess, try holding the on/of switch in a little longer, some systems act as reboot/reinstall
Apr 14, 2013 | Apple iMac G5 Desktop
Why do only the fans work on my imac a1058
Hi Joseph,
Well it's a 9 year old iMac.. it sounds to me like the power supply has failed. Nothing under $300 to fix unfortunately
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Dell inspiron 1520 laptop keeps freezing after a few minutes after being turned on. It wont respond to Ctrl +Alt+ Delete and doesn't sleep when its closed. The screen turns black if you keep clicking the...
boot the computer in safemode. check if it will still lock up. if it does then run a hardware diagnostic test. if it doesnt clear the startup by opening the system configuration utility then disabling the items under the startup tab then rebooting to normal mode. regarding the computer not going to sleep mode when closing the lid, visit the power options in control panel and check the settings on what the computer does when you close the lid.
Mar 27, 2011 | Dell Computers & Internet
I have a Dell Dimension 8400 PC desktop. When I tried to turn it on the fan will start and it will begin to boot but then suddenly stops and the light on the front goes from green to yellow. (Not...
Try going into Safemode. If the system stays on while in safemode, when try disabling start up items.
To go to safemode, press F8 when starting the PC or while you see the Dell logo.
To disable start up items, Click on Start>Run>then type MSCONFIG, then press "Go". IN System Configuration Window, click on Startup tab, then uncheck all the items. You can also use this link as guide.
http://imasters.japancase.com/msconfig/
If the system works find on safemode, or after removing startup items, then you have a software issue. OS reinstallation is easiest approach.
Mar 05, 2010 | Dell Computers & Internet
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
I have a advent notebook which wont turn on and sais that an error accured whilst trying to load configuration settings?????
You may have to contact Advent to try to get a recovery CD - however, there are a few things to try.
1) Try booting the system into SafeMode. To do this, as soon as you turn the system on, tap the F8 key und you will get to the Startup Option screen. Use the arrow keys to highlight SafeMode and press 'Enter'. This will either work or it won't and it may freeze with the error. IMPORTANT: Write down the error - we may be able to find a workaround with that information.
2) If you cannot get to SafeMode, reboot the system and follow the same process to get to the Stoartup Option screen. This time select SafeMode with msdos prompt. If you can get there, we can possibly run a System Restore in DOS and turn your system back to before you had the issue.
Let me know how you make out and we'll move on to the next step.
Good luck,
TIH
Dec 30, 2009 | Advent 4211c Notebook
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
K
Sep 14, 2009 | Apple iMac 24" Desktop
Apple iMac G5 Desktop Logo
2,552 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
