Question about Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS
It turns weakly to loosen, and not very strong to tighten.Have removed the air chuck, and it is not plugged
    Scholar:
  • 172 Answers
Check to see that the power regulator dial is set to its highest number. The forward/reverse selector is also the power regulator and can be turned from 0 to usually 5. Look at your impact gun from the side and you should see the numbers next to the forward/reverse knob.
Posted on Jan 27, 2010
How can I remove the chuck?
Most drills have a chuck that screws on to a threaded shaft that extends inside the motor. Repair shops know how to "freeze" that shaft so it will not turn, allowing you to unscrew the chuck. One model of drill has a tiny hole that you insert a nail into to remove the chuck.
Mar 15, 2016 | Drills
The chuck will not loosen or tighten only makes a partial turn. How do I repair
Try to get it to open enough to get a Phillips screw driver to go in. Push it in to engage the screw holding the chuck to the motor shaft. Remove the screw and replace thee chuck.
Jun 17, 2015 | Drills
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I replace the chuck on a craftsman model 315.101370 hammerdrill
The chuck can be removed and replaced with a new one.
Unplug the drill.
Insert a 5/16 in. or larger hex key into the chuck of the
drill and tighten the chuck jaws securely.
Tap the hex key sharply with a mallet in a clockwise
direction. This will loosen the screw in the chuck for
easy removal.
Insert the hex key into the chuck and tighten the chuck
jaws securely. Tap sharply with a mallet in a counterclockwise direction. This will loosen the chuck on the
spindle. It can now be unscrewed by hand.
Feb 15, 2011 | Craftsman Drills
My black and decker 12v drill is 'locked". The area where you put the drill bits in won't loosen or tighten so it won't hold any bits. I have tried to manually loosen or tighten it too but nothing...
Try shooting some WD-40 lubricant into the 'chuck' and let it sit for awhile, then rotate the outer part of the chuck CCW to loosen the 'jaws'. If the chuck is a keyless type, just hold the chuck and turn the reversing switch to 'reverse', then gently apply power to the trigger--that should open the chuck jaws. You will likely find that a leather glove on the hand holding the chuck will help prevent a burned hand if you lose your grip. If it is a keyed--type chuck (there will be ring of gear teeth on the front edge of the chuck), then a key with a small gear near one end is required to turn the chuck open (turn the key CCW). Hope this helps!
Jan 25, 2011 | Garden
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a craftsman electric drill model no. 315.10419, i would like to know how to loosen/tighten the chuck for the bits. it is not the regular notched tightener but has a pull down shaft similar to an...
I have the same drill and love it !! This series of Craftsman Drills are the first of the keyless chuck. To tighten or loosen the bit, simply pull back on the black ring tightly and hold it and simultaneously pull trigger to run drill foreward (to tighten bit). Reverse (to loosen bit). The chuck will make a loud clicking sound!! This is normal !
Jun 23, 2010 | Craftsman Drills
Can't tighten or loosen the "keyless chuck" inorder to put in a bit
What you need to do is get a piece of strong strapping, on a stick like a jar opener, or a vice, or some way of "Grabbing" the chuck, other than you hand, even using the inner edge of a door frame and "Grip" the Chuck, Now with a nice fresh battery installed, put it in "Reverse" and holding the chuck tight operate the unit and it should undo itself.
Feb 24, 2010 | Black & Decker & Cordless Drill
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Feb 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS Logo
111 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
