Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 Red Battery Light
I have an Acer Aspire 5100 and for some reason it's not getting any power. I have a Kensington Universal Adapter and the first sign of the laptop not working was having to mess with the power cord like an old pair of headphones. Then I used the all purpose connector on the adapter and the battery light goes on red for a second then turns green again. It turns on and what not but the thing doesn't boot up! Is it a battery problem? I know some laps dont work w/out the battery plugged in.
  • 4 Answers
Make sure your universal charger is EXACTLY the same voltage as the old charger. I had a dell laptop that someone and had a universal charger on it and the cpu would always run in powersaving mode and the battery wouldn't charge so I bought a dell replacement off of ebay and it fixed it. Just a side not, the battery light would flash red non stop.
Posted on Feb 26, 2009
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Posted on Dec 11, 2007
Acer aspire 5100
Remove the main battery, it is probably loading the power supply down. If your computer starts up, replace the rechargeable battery.
Apr 14, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
WILL NOT CHARGE OR POWER ON
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
I HAVE A ACER ASPIRE 5100 & WHEN I TURN IT ON THE SCREEN IS BLACK & WONT DO ANYTHING. THEN ABOUT ONCE EVERY SO OFTEN IT DOES BOOT UP BUT TELLS ME THAT I HAVE TO REINSTALL WINDOWS & WHEN I GOT...
You might have a bad AC adapter, bad Battery or bad motherboard.
1.) AC Adapter about $60
2.) Battery around $100.00
3.) Motherboard around ?
I would start with adapter first. If you see that you have to go to Number 2 or 3. You might to just get a whole Laptop, if this one is not still under warrenty.
Mar 14, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Acer aspire 1500 will not turn on
Try removing the battery and running the power directly through the power outlet. HP laptop dv6000 has the same problem.
Nov 06, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Mar 22, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
My acer aspire 3690-2050 has stop working
Can you be more speciffic? What were you doing when it stopped? Did it just shut off? Will it attempt to boot up at all? Are you using AC adapter or battery power? More info plz.
Aug 31, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 start up problem
If you dont hear any beeps. Then most likely the motherboard is faulty.
Replacement parts can be ordered from www.acerparts.com
If you need more assisntace, let me know.
Mar 27, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
325 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
