How do you install new ram - Computers & Internet
  • smoov215 May 11, 2010
    are you talking about system ram or on the graphics card itself?
    President:
  • 2,030 Answers
Install it into what?
If you mean your video card, not all video cards will let you do this.
Check the owners manual or the video cards website.
Posted on Sep 11, 2009
System not booting after ram upgrade
Sometimes it passes a poorly designed ram test, probably faulty ram, speeds always default to the slower of a pair. Some computers need all slots full. Did you buy it new? We have Re-PC for used components in the Seattle area, a great resource.
Jan 11, 2014 | Intel D102GGC2 Motherboard
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
Hi I have intel motherboard D945GCNL with Dynet 1 GB ram installed. I boght a new Dynet 1gb ram and installed it. After that, my cpu began beeping.So I removed the ram and interchanged the rams.It doesn't...
Your RAM needs to be:
  • DDR2 667, DDR2 533 or DDR2 400 MHz SDRAM DIMMs
  • Non-ECC DIMMs
  • 2 GB maximum total system memory
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: double-sided DIMMs with x16 organization are not supported
  • Make sure the New RAM is not bad.
    Ensure that the new RAM is the same type as your old one (DDR2 XXX)
    Install the old one back and make sure that your PC works.
    If it does, Take the Old RAM out and install the New RAM in the same slot as the old one.
    If the PC does not work with the new one, It is more than likely a bad stick of RAM
    Hope this helps
    Dec 20, 2010 | Intel D945GCNL Motherboard
    I want to upgrade the standard 512mb RAM to 2GB. once installed do I just restart the computer or do I need to do something to allow the computer to recognize the new RAM?
    You should be fine to just turn the computer on straight away as soon as you have installed your new RAM. The computer will recognize the new upgrade straight away provided you have got memory that is compatible with the desktop computer.
    When you upgrade the RAM take the old RAM out and make sure your new RAM runs at the same speed as your old RAM.
    From what i can remember the maximum RAM speed that an HP pavilion supports is 400MHz although it could well be 333MHz.
    The RAM that's installed in the desktop at this moment in time will have the speed on it so you check with that.
    Regards.
    Jan 25, 2010 | HP Pavilion a450n PC Desktop
    Laptop doesn't recognize new ram
    I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
    This is the requirement for your laptop from www.crucial.com
    Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
    Hope this helps
    Apr 09, 2009 | Gateway Computers & Internet
    Installed more memory into Compaq V2000
    The new ram you have installed, is it the same speed/type as what is already in the system?
    Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
    http://www.bioscentral.com/beepcodes/compaqbeep.htm
    Jan 17, 2009 | HP Compaq Presario V2000 Notebook
    P4m800-m7 Rev:3.1 RAM PROBLEM!
    the problem is with the new ram.
    its phsically damged.
    may be little bit that you cant see it.
    try checking the other 1GB ram.
    Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
    Pentium 4 comptability with SD Ram
    If you know what mother board you have you could check what RAM it can use.
    All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
    To install ram on a PC
    Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
    1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
    2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
    3. gently insert the RAM into the RAM slot
    4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
    That's it! :-)
    -Magnon
    May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
    RAM Installation.
    your new ram fsb speed not support your mobo
    845glly mobo support 266 fsb 133 mhz sdram
    Feb 29, 2008 | Intel D845GLLY Motherboard
    Bios
    try to come back with old configuration second time check new ram , may be something no good
    Dec 10, 2007 | ASUS A8V-VM Motherboard
    Computers & Internet Logo
    26 people viewed this question
    David Payne
    David Payne
