Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
    President:
  • 632 Answers
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Posted on Sep 11, 2009
WS 65613 MITSUBISHI
your problem is in the power supply.check the regulator
Nov 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65613 power problem
kindly check the settings.. could be the sleep timer was set ON..
Let me know here again..
`jack
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green blinking light and tv would turn on
blinking light is an error code. Check the manual for it's meaning.
Aug 14, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65 in. Rear
Bad DM module = replace or repair by skilled Mits tech only....
Research my solutions or comment,please.....
Oct 17, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
