Question about Kitchen Ranges
I have a Maytag Maytag MGR6772BDW. One burner fails to light
I have a Maytag MGR6772BDW. All 4 of my igniters spark. 3 spark up to the metal plate on top, one sparks down to the burner and fails to light the burner. I have cleaned the burner, sanded the contact points on top of the burner with no change. I even tried sanding the bottom of the metal disk to see if it needed a better contact. Is the igniter too low and can it be adjusted? Why would the spark jump down to the burner base rather than jumping up to the top disk?
  • 135 Answers
Clean out the hole that lets gas to the spark area. You can bend the ignitor probe closer or farther away so that it goes to the path of least resistance. It should lite unless the gas is not getting to the spark area.
Posted on Sep 11, 2009
Oven turns off while baking
There is a service flash, W10622771, for gas ranges of your model number--the bake burner ignitor is not lighting the gas--it's a direct spark ignition type. The ignitor is sparking but no ignition. Possible causes are (1) Wiring harness might be pinched between the bake/broil ignitors and the DSI board. (2) DSI mounting bracket may be contacting a solder joint on the back of the board. (3) Positioning of the ignitor and gas burner ignitor ports may be out of adjustment. (4) Ignitor electrode deterioration
Facing the range, the DSI board is behind the control panel on the left side, mounted in the bracket.You'll have to remove the back cover to expose the boards. BE SURE TO UNPLUG THE RANGE BEFORE DOING THIS. I can provide diagnostic mode if you want to proceed further.
Aug 09, 2015 | Maytag MGR8700DH MGR8700DH 5.8 cu. ft....
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
My Maytag kitchen range left front burner does not ignite/clic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Sep 05, 2010 | Maytag MGS5770 Gas Kitchen Range
Front burners on gas range won't light.
My GE gas range is really sensitive about the gap between the igniter electrode and the metal disc that covers the burner. If the metal disc is slightly off-center, no spark will occur. Check to make sure that the gap between the igniter and the nearest metal is about the same as the back burner.
Jul 25, 2009 | Kitchen Ranges
One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Jun 26, 2009 | KitchenAid Cooktops
Burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Jun 20, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Igniter
It is normal for all 4 burners to spark at same time.  Often burners won't light even when you can see the spark at them because the burner is dirty.  Take a pin and clean out all the holes in rim of burner.  Also look for small cracks in white part of igniter.  If cracked it must be replaced.
Oct 21, 2007 | Kitchen Ranges
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
