I am looking to purchase this heater and was wondering what temperature it can bring a space up to. I am looking to use it as an incubator heater and need it to get to 101 degrees F.
Comments:
Dec 10, 2007
- i am looking to heat a space the size of an oven with it.
the two lights on the dual control unit of my morphy richards electic blanket flashes on and off and...
(More)
the two lights on the dual control unit of my morphy richards electic blanket flashes on and off and im getting no heat on that side of the bed the other sides working fine.if i swop the controls round this works that side so the problem seems to be with the control unit any sugestions would be appretiated thanks
Heater on level surface, when plugged in heater will heat for 3 to 5 minutes then shuts off and does...
(More)
Heater on level surface, when plugged in heater will heat for 3 to 5 minutes then shuts off and does not turn back on
Hi, Morphy Richards Electric Blanket, not working, no neon. Using a multmeter, it looks like the...
(More)
Hi, Morphy Richards Electric Blanket, not working, no neon. Using a multmeter, it looks like the first component has failed. Totally blocks the AC, cannot identify it. Is it some kind of resistor or fuse (looks like a long white resistor with no markings)? Thanks.
How to replace the power cord on a Honeywell Ceramic heater model #HZ-341BL? Does the grille have to...
(More)
How to replace the power cord on a Honeywell Ceramic heater model #HZ-341BL? Does the grille have to be removed in order to access the screws beneath? And if does, how is it removed? Gently prying doesn't work.
I bought a used HZ-510. It seemed to work fine pre-purchase. After getting it home, it cycles off...
(More)
I bought a used HZ-510. It seemed to work fine pre-purchase. After getting it home, it cycles off and on. On about 1 to 3 min and off 3 to 5 min. I removed the cover to diagnose the problem. I cleaned the temperature sensor located right over the ceramic coils, it had a small amount of dust. The thermostat seems to operating properly as it calls for heat and stops calling when it is turned down or is satisfied. The fan is operating, the blades are clean, the coils are clean. I see nothing that would indicate improper air flow. The only thing that is throwing me is what apears to be a temperature sensing device on the thermostat knob itself. With the pendulum type wighted cylinder that opens the contact. It is getting hot to the touch, is there a desighned temperature it is supposed to reach and not exeed? I understand that being purchased used and not being the original owner it may not be under warranty. Any ideas as to what is the problem and where to get parts if needed? By the way, I am a heating and air conditioning contractor in NC if that makes a difference.
