I have a toshiba A215 and it will not charge. When I plug in the adapter, it says charging for a few minutes then it says plugged in but not charging....what could be the issue?
  • msg2381 Sep 11, 2009
    Well I know the charger works b/c I have another toshiba that has the same outlet and it charges that computer fine...how would I check to see if its a jack problem and if I have to replace the motherboard, will I still have everything on my computer?
    Do you know how much it would cost to get the jack replaced? So if I was to just replace the motherboard, I would just need a vista home operating disc to install when I first turn my computer back on....correct?
    President:
  • 2,600 Answers
First thing I would do is check the outgoing voltage from the adapter. If it is going bad the faulty regulator could end up frying your motherboard. Laptops are very finicky about their power and it does not take much to screw them up permanently. Think simple first as in power adapter, then DC jack problem, then motherboard power circuit.
Posted on Sep 11, 2009
  • Chip
    Chip Sep 11, 2009
    Changing the motherboard won't make you lose any of your data, but when you go to fire the computer up for the first time, you'll need your operating system disc to initiate the boot sequence because of hardware changes.Usually these problems are adapter failures or Jack failures and the jack failures are common becauseof the stress involved in the plug and socket. There is a good deal of stress put on the socket from the adapter plug and after a while things tend to wear out and break. the solder points around the jack the connect it to the circuits of the motherboard tend to crack and separate over time (Cold Solder). I will give you a service manual link below. Click on it and download a copy for future refernce so you can study it, print it, do what you need with it. Unless you got hit with a power spike through the homes AC system, I can't see that the motherboard took a bad hit from something. Good luck, ParrotHead PC Repair
    http://www.irisvista.com/tech/laptops/to...
  • Chip
    Chip Sep 11, 2009
    If just the Jack is bad, the jack cost around 15 bucks and you would have to check with a shop what the labor would be to de-solder the old one and solder in the new one. Motherboards for that can be bought on E-Bay for around 150 bucks if not cheaper. If you are lucky, there won't be a need to use a windows installation disc for startup, but in my experience it is most likely that you will. The sure thing here would be to replace the entire motherboard if you don't have the resources or you don't want to wait on testing for the bad component. I find most PC shops (the smaller mom and pop type) will take the time to hunt for the bad component other than just telling you the motherboard is bad...re: The Geek Squad". Just make sure of what the ptoblem is before you go puring money into changing out parts that may or may not be the root of the problem.
Rdrhow to find recharge componets on a215-s4807 motherboard?
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
My Toshiba Satellite A215 - S7422 won't charge and
a problem with the battery or a charger.
Jul 17, 2012 | Computers & Internet
I have a Satellite A215-S4807. The original battery went completely dead (possibly from this problem), so I just went out and got a new one with a 4800mAh, which is slightly higher than the 4000 it came...
There is something wrong with the "recharger" components on the computer's motherboard.
Instead of charging the battery, and then stopping the charging process, it is "draining" your batteries.
Take your Toshiba to the nearest qualified Toshiba service location, to get it fixed.
Aug 26, 2011 | Toshiba Satellite A215-S4807 Notebook
Toshiba satellite a215 loses connection with power cord
The fault could be the adapter plug (a broken wire at the plug) that connects into the laptop or a faulty power socket on the laptop. In most cases it is the power socket on the laptop, it could be just a dry solder joint in the circuit board where the power socket is soldered on the motherboard or the power socket is faulty and therefore needs to be replaced.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Mar 06, 2010 | Toshiba Satellite A215-S4747 Notebook
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
Charging issues with a toshiba A215
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 11, 2009 | Toshiba Satellite A215-S7422 Notebook
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
340 people viewed this question
David Payne
David Payne
