Question about Craftsman Garden
The engine wont turn over. I can see it turn slowly(as fast as a snail) and then stop. I put a new Kohler starter on it and it still turns to slow to start. What is wrong with it.
  • 3 Answers
If you have a multimetter mesure the value from the ground to positiv polarity of the starter-value must by lower 30 ohm.if there is good please check mechanical coil starter contacts and the batery. try to recharge the battery .if doesn,t work propertly the last solutions it,s to change the schaft bettw. starter and engine.be sure to the moment when you press bettw. (screw) starter -engine body.
Posted on Sep 11, 2009
It wont turn over even with a new battery. What could it be. It slowly started tuning over slow before failing completely
Sounds to me as if your starter is dead. Do you hear a click every time you turn the key? If so, then it is your starter. You can try hitting it with a hammer or something hard and try to turn. Chances are it will turn over but sounds as if the brushes are dead.
Mar 07, 2015 | 2003 Oldsmobile Alero
Kholer engine engine repair
remove starter houseing cut old rope out then rewind it till it stops slip new rope through houseing hole and pull hole put a screw driver threw houseing and pulley to make it so it cannot unwind then not the pulley end of rope take a lighter heat knot this will make sure it will not unknot hold rope pull out screw driver pull rope until knott is seat to pully slowly let cord rewind cord until it stops pull out two tune of pully install handle put knot in it and heat the knot with a lighter done cut excess cord off reinstall the red neck let me no if you get have problem like motor dont star or is hard to start
Aug 28, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a new bad boy mower with a 747 cc Kohler engine, the motor has 9 hours on it but the engine surges at anything but wide open
you need to adjust carb on the side of carb there is a mixture adjustment screw on slow slowly turn screw out until surging stops now go full throttle if die need rebuild carb if runs fine your done
Aug 10, 2014 | Garden
How to remove clutch kohler 23 hp command series?
remove the bolt... if it still doesn't come off the safest way is to put a sacrificial bolt back in and use an air hammer to hit the bolt as the clutch slowly comes off... pb blaster helps a lot
May 18, 2014 | Kohler Engines NEW 23 HP KOHLER ENGINE...
Engine turns over slowly
Try measuring battery voltage at the starter motor. Should not drop below 12V when cranking.
If does pull plugs and see if you can hand crank. If more is really tight try some very light oil in cylinders for a couple days and see if anything loosens up.
Feb 26, 2018 | Cars & Trucks
40hp evinrude wont turn over with starter
starter or battery not sufficient capacity to crank the engine fast enough under compression
Jan 01, 2018 | Boating
88 rx7 run but wont start
The FC3S is notorious for this and fueling issues. Check all ground points, battery cables and connections. Check the draw from the starter. If the voltage drops below 10V there is not enough power for the ignition, causing weak spark. It really needs to spin over 200rpm cranking. Pop starting does not necessarily mean the compression is good. You need to make sure it cranks fast enough to get a proper compression test with rotary tester, New NGK plugs, new NGK plug wires.
May 28, 2012 | 1988 Mazda RX-7
Car turns over slowly, wont start
Put a volt meter across the battery terminals. You need at least 12v there in order to get the starter turning. If voltage is less, have it charged and load tested then try again. If it still turns too slow, put the volt meter back on and check voltage while turning. If it drops below 9.5 volts while cranking the starter is likely at fault and needs replacement.
If you have a security system make sure you know how to re-arm it before removing the battery. Check the charging system after you get it started. and make sure belt is not slipping as well.
Jan 15, 2010 | 2002 Chrysler PT Cruiser
Wont start
Is starter engaging but is turning the engine slowly then not turning engine? (that's what I'm reading) If so, check both connections at the block and starter. If reading proper voltage 12v or better, check voltage across battery when in "start" if it drops below 9.5v the starter has failed. (you can turn the engine by hand...correct?)
Apr 25, 2009 | Jeep Grand Cherokee Cars & Trucks
Problems turning over 96 ford taurus gls
does the engine turn over fast when you try to start it are dose it turn slow . if it is slow to turn over it could be the starter are the battery has a bad cell and also make sure the alt is charging .
Jan 21, 2009 | 1996 Ford Taurus
Garden Logo
146 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
