Question about HP Officejet Pro L7680 InkJet Printer
Hp officejet pro l7680 alignment failed
I tried the four reset options offered by HP - nohing works. Help?
How do I clean HP officejet Pro L7680 All pictures have severe vertical lines??
Have you tried the "clean print head" option in the HP Officejet Pro software on your computer? This will often fix verticle lines. But, it will use a lot of ink.
Nov 04, 2014 | HP Officejet Pro L7680 All-In-One Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Alignment failure HP L7680
Check the quality of all your cartridges. Some printers are very fussy over alignment pages - if cyan is not coming through and is needed for example, the alignment will fail.
Feb 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printhead problem
I suggest you take a look at this resource: HP OfficeJet Pro L7680 Drivers & Troubleshooting
And nikioc is right; more (descriptive) information is required about your problem to help.
Kind Regards,
Dec 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
My officejet pro l7680 is printing with words
if the ink level is more than half then try to clean the cartridges and the contacts on the printer with a lint free cloth and from printer options as well..
on printer..
press setup button > go to tools > try to clean cart / align the cart and then try to print..
if it doesnt help try with another set of cart.
Oct 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Alignment error on the HP L7680
you need to reset the printer using the # and the number 6 buttons and while holding down the buttons plug in the power cord.See if it works else try the same with # and the number 9.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
Alignment failed even after a full reset. WTF!
If you JUST GOT the printer and it is being a difficult printer - call HP. They can help you get it returned for a different printer. You may just have a "bad" one out of the box.
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 InkJet Printer Logo
922 people viewed this question
Seeker5211
Seeker5211
