Question about HP PSC 1315 All-In-One InkJet Printer
Cannoy access HP Director. Error message: -
Cannot access HP Director.
Error message: -
The file HP\digitalimaging\skins\oov1\skin.xml does not exist.
What do I do?
    Brigadier General:
  • 10,406 Answers
Uninstall the HP software:
Start
Control Panel
Add/Remove Programs
Select HP
Remove
Restart.
Re-install the software.
Access HP Director.
Posted on Sep 11, 2009
Getting error message Invalid skin file error line %i in the xmlwhen entering my Karaoke Programme On my Acer Aspire 8.1
This means the .xml was expecting some information when the page is accessed, and either the information given is wrong, like wrong file type, or damaged file, or missing the name or the file. So, if nothing has changed since you last used it; then either a file is missing or corrupt, or you've changed devices, or an upgrade to your current system has killed the app.
Sep 01, 2015 | Acer Computers & Internet
Error loading skin on roxio 10- everything else works but making dvd
This error is usually caused by corrupted MSXSL 4.0 files. Download and install the latest XML 4.0 update from Microsoft. Please refer to the link below:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7F6C0CB4-7A5E-4790-A7CF-9E139E6819C0&displaylang=en
Cheers . . .
May 21, 2010 | Roxio Easy Media Creator 10 Suite
Invalid skin file (error line %i in the xml) Virtual Dj Problem
you may install theme that not capable to the current version
my suggestion is changing it back to the default one first, then choose theme that capable to the version you have
Apr 09, 2010 | 3M Pro One Dispute Resolution
Hello !!!! I would like some help about Virtual Dj .When i am going to start it appears this message "" .How can i fix it ??? :(
Jun 06, 2009 | 3M Pro One Dispute Resolution
Hi, when I want to open scaner in hp office jet6213 I recieve this message "selektskin-error" (the file c:program fileshpdigital imageskinsoov1skin.xmldose not exist) What should I do?
The 'missing' file exists, but is in the wrong folder. This problem is known to HP. Here is the solution:
# Open Windows Explorer.
# Click the + sign next to Local Disk (C:).
# Click the + sign next to Program Files .
# Click the + sign next to HP or Hewlett Packard .
# Click the + sign next to Digital Imaging .
# Click the + sign next to Skins .
# Make sure there are only two folders; one named hp1 and one named 00v1 . If there are any variations to the folder name, or extra folders, delete them.
# If there are not any extra folders, check the contents of the folder and make sure they are correct.
1. Look inside the hp1 folder; it should contain sixteen icons (including folders).
2. Look inside the 00v1 folder it should also contain sixteen icons (including folders).
What you will probably discover is that the skin files in the 00v1 folder are all or partially missing. Copy all the files in the hp1 folder to the 00v1 folder, and be sure skin.xml is one of these files. And if there are any other folders in that subdirectory delete them, and if the 00v1 folder is missing, create it.
You can go to the following site for a deeper discussion of this error message: http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00215691&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Apr 28, 2009 | HP PSC 1315 All-in-One Printer
EVERY TIME I use my scanner ie scrips errors involving - file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm comes up
Hi I encountered a similiar problem with my HP PSC 2310 printer recently. "file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm". Following are the soultions provided by HP team. Solved mine using solution #1. Hope this is of help :)
Solution 1:
1. Double-click on 'My Computer' icon on the desktop.
2. Double-click on C:
3. Double-click on 'Program Files'.
4. Double-click on 'HP' folder.
5. Double-click on 'Digital Imaging' folder.
6. Double-click on 'Skins' folder.
7. Locate and double-click on 'hp1' folder.
8. Locate, right-click on 'skins.xml' file and select 'Copy'.
9. Click on the 'Back' arrow to go to the 'Skins' folder.
10. Double-click on 'hp2' or 'oov1' folder.
11. In the folder, right-click on any blank space and select 'Paste'.
12. Now restart your computer and check the functionality.
If the issue still persists, please follow solution 2.
Solution 2:
1. Insert the All-in-one software CD in your computer and cancel any installation screen that may appear.
2. Double-click on 'My Computer' icon.
3. Right-click on the CD-ROM drive that contains the software CD and select 'Open'.
4. Double-click on the 'Setup' folder.
5. Double-click on the 'SkinsHP' folder.
6. Right-click on the file 'SkinsHP1.MSI' file and select 'Install'.
7. Again right-click on the file 'SkinsHP1.MSI' file and select 'Repair'.
8. Restart the computer and check the functionality.
Solution 3: Uninstall and reinstall of the software.
1. Insert the CD that came along with the printer.
2. In the CD contents, you will be able to view a folder named "UTIL".
3. Inside the UTIL folder there will be a folder named "CCC".
4. In the CCC folder, among the various files, you will be able to view four files named, Uninstall_L1.bat, Uninstall_L2.bat, Uninstall_L3.bat and Uninstall_L4.bat.
5. First double click on Uninstall_L1.bat file. A black DOS window will open up. This will uninstall the software by Level 1 method. It will take a while until Level 1 uninstallation is complete.
6. Similarly complete level 4 uninstallation by clicking on Uninstall_L2.bat, Uninstall_L3.bat and then in Uninstall_L4.bat.
7. This completes level 4 uninstallation of the software.
8. Now install the software from the CD and check if the issue is resolved.
Cheers,
kypsyche
Jul 10, 2008 | Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
280 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
