Question about Lexmark X5450 All-In-One InkJet Printer
Ink rejection of ink refills
Cartridges were refilled from Walgreens and the fax/printer is reading them as ERROR #1203, cartridge error
Printer just has following message Error 1203 consult user's guide" which I do not have
Error 1203 comes from a refilled ink cartridge.
Try purchasing the Brand name ink cartridge and the error message should go away.
Rick
Jan 09, 2011 | Office Equipment & Supplies
Dell all in one printer 964... Error message 1203... What does this mean? I recently had the ink refilled at Walmart. The printer did work after the ink was refilled, but now it's being very odd and will...
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 27, 2010 | Dell 966 All-In-One InkJet Printer
The cartridge was refilled at Walgreens. The
This might well be another case where saving $ on a refill has cost you the wasted ink you bought. In my experience, refilled cartridges and 3rd party cartridges just dont cut it. Replace your cartridges with the OEM products and you will not go far wrong.
There will probably be others who have had other experience, this is mine and my recommendation.
Thanks for your quesiton.
Dec 30, 2009 | Office Equipment & Supplies
Ink.leaked.from.refil.now.readserror#1203.cartridg...
You can refill the cartridges with ink but what they don't tell you is the cartidges can only be use 3-4 times if not less...the electronic package on the cartridge is not designed for multiple use. You may have to install all new cartidges and if the system has been corrupt, you may to uninstall and re-install the device for it to work.
Aug 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
Error # 1203 Cartridge Error
Have you recently refilled or replaced any of the cartridges. 1203 is usually one of two things.
1. An overfilled cartridge (fixed by wrapping in damp paper towel for a bit until excess ink wicks out)
2. Ink smeared on contacts (fixed by cleaning contacts on cartridge and on printer's cartridge housing)
Aug 05, 2009 | Lexmark X7350 All-In-One InkJet Printer
Error: Remove and replace color cartridge
Because the software inside the cartridge was not reset. They do not have the electronic equiptment to do that.  I believe you woudl have to refill the ink before you got the empty mesasage?
Mar 13, 2009 | HP OFFICEJET PRINTER
HELLO! I HAVE A SHARP FAX MACHINE (UXA1000- INK CARTRIDGE UX-C70B)AND I WANT TO KNOW IF I CAN GET THIS CARTRIDGE REFILLED AT WALGREN'S STORES LIKE MOST CARTRIDGES.
You should be able to, but the problem is this:
they only refill it, if there is a problem with the cartridge it doesn't help.
there is more to just putting ink in a cartridge.
1- you must clean the inside removing dried ink
2-you must clean the nozzles tomake sure the ink can flow
3-replace any pads inside
4-refill ink
I have heard complaints about Walgreens so take your chances, a better solution may be a company called Rapid refill ink ( they do all the above to their ink crtgs)
Jul 30, 2008 | Sharp Office Equipment & Supplies
Printer
Hi , use the genuine canon ink cartridge the printer can identified the ink cartridge. and colors.
Feb 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Lexmark X5450 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
