Question about Mitsubishi VS-45607 45" Rear Projection Television
Vertical and horivonal are "Flipping out"
My picture wont stay still and i cant figure out where to correct them at on my tv. On other tv's you could fix this in the menu but them are not options in this menu.. please help I'm flippin me out
Thanks nikki
  • nichole9584 Sep 11, 2009
    i have no ideal where or what any of that is....
  • 24 Answers
Check the sync circuit.To be more precise the sync seperator line. or the filter capacitors associated with the sync circuit power supply stage.
Posted on Sep 11, 2009
  • Johnsheen A Sep 15, 2009
    Nikii, this must be problem inside.If you are a technical person please check the sync line. I know it is little time taking job in the absence of a circuit diagram. One way is to check a common signal line which connects both Horizontal and Vertical oscillator sections. Likely some resistor must be open, or sync seperator circuit. If you find it hard just reffer to a service personnel who are good at TV.
HOW DO I FIX THE VERTICAL HOLD? PICTURE KEEPS FLIPPING
Before trying anything else try resetting the TV to the factory specs.
To do this simply turn the TV on using the power button on the TV while holding the reset button on the remote. While you are still holding the reset button the TV should turn itself off then back on again.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Our tv worked fine last night and now at first it was really dark and now it is flipping. What do I do?
The loss of brightness is probably caused by degraded high-voltage internal to the set. This can be caused by an electrical "brownout" that will correct itself.
The flipping problem is due to a degraded vertical synchronization signal. First make sure you have a strong signal - no loose antenna/cable connections, etc. Assuming you have a strong signal (i.e., no "snow"), analog TVs sometimes have a so-called "secondary control" (labelled "Vertical Hold", "VH", "Vert", etc.)located on the rear of the set. If you are lucky you may have one and be able to adjust it and regain stability.
Old sets used analog components (which age with time and are somewhat heat-sensitive) to control the vertical sync. Modern TVs use digital signal processing techniques that need no such controls.
Probably need to take the set to a repairman, if you can find one.
Aug 25, 2009 | Televison & Video
Tv stays black
Do you have audio and if so can you change channels to hear other programs? If so ...you have a bad vertical IC. Have a tech turn up the screen control to see a white horizontal line. By your question I would say this will correct the problem.
Jul 26, 2009 | Sanyo DS27510 27" TV
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Jan 10, 2009 | Toshiba 36A40 36" TV
Vertical flipping
I bet you put it into PAL mode, the European standard. I believe that you can reset to factory default using the menu and it should be okay. If you cannot read and navigate the menu tree, then I think that if you hold the power button on after you start up, it will reset itself. I have not checked the doc to make sure of the last.
You can also get display problems if you pick the Y/R/G component setting in the menu. It is designed for connecting to a high definition using 3 different cables, one for each color. It only supplies vertical on one of those cables, and the TV just doesn't know what to do without the vertical blank signal from 'somewhere'.
Again, a menu setting.
tom
Dec 05, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
Hitachi 57g500 vertical problem
Yup you are getting ripped off. Get another techie to have a look.
Sep 24, 2006 | Hitachi 57G500 57" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
