Question about Dryers
Maytag ensignia dryer MDE7657BYQ. Are the flaps
Maytag ensignia dryer MDE7657BYQ. Are the flaps inside the drum called baffles? One of the three is loose, moves around and clangs when it is running. Can this be tightened up if I can get the top up? If so, how do I get the top up? Thanks for any assistance...
  • 110 Answers
Yes it can be tightened, you would have to take off the door, there should be 2 screws on left and 2 on right, then you would have to take off the dark brown like bolt on the left and right, there is a long L shape clip that holds top to front. Once you lift top tightened the bolt or add a bolt to the baffles..
Posted on Sep 11, 2009
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
2 dryer bars
The bars are called BAFFLES P/N: 12002559
They are attached by 4 screws through the drum. You must pop the top to reinstall the baffles. Take one of the baffles to the hardware store and buy some good fitting screws. Then pop the top 660ff1d.jpgand use a screwdriver to reattach them. Fairly easy to fix. IF you have the old ones. Do dry tennis shoes in there. Oopz LOL
Apr 22, 2010 | Maytag SDG3606A Gas Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
Interior drum one of the three turner shelves fell off into the drum during the cycle - help
Unplug the dryer
Unplug the dryer
UNPLUG THE DRYER
remove the top and remove the front panel look for the screw(s) that fell out at the inside under the drum use a flashlight and a magnetic pick up tool screw the baffle back in replace front and top.
Sep 03, 2009 | Maytag Dryers
Inside the drum there are three paddles and one has worked it's way lose. What is the name of this part and is it something that will snap in place easily, or must I get professional help installing?
it is called a baffle. two screws hold each in place, and is is common for them to gradually loosen. it is also easy to tighten them back. open the door, there are 4 screws on each side inside door frame, remove them. then pull the front panel from the sides towad you, the pannel will come foward then lift up and set panel aside. there is 1 screw on each side holding the top down, remove them then top hinges up. you will be able to see the drum and as you turn it you can tighten the screws to all 3 baffles, then re-assemble. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
What is this called
they are called "drum baffle" and you can order online at Repairclinic.com...
great source for parts. check here : http://www.repairclinic.com/Maytag-Dryer-Parts?n=8
May 25, 2009 | Maytag Dryers
Dryer
Hi thanks for the question. the top of the dryer comes off. revealing the screws that hold the baffles in place . re- install the baffle, and the top. thanks the appliance doc.
Oct 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
259 people viewed this question
Top Dryers Experts
