Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The picture is kind of dull. the cable guy suggested putting in a new bulb. how do we figure out exactly what part that is?
  • tvtechlady May 11, 2010
    need model number and brand
  • Panasonic Master
  • 8,617 Answers
Your model doesnt have a lamp as the PT47WX53 is a rear projection with three CRts. Sounds like the mirror needs to be polished as that can make a picture appear dull and washed out
Posted on Sep 11, 2009
When i take my lamp out of my rca hd61lpw42 there is a small glass cracked any clue whats that about!! Also I inserted my new lamp and picture is dark and kinda dull any suggestion to bring out my colors...
YOu need a better description of what the cracked glass is.
Also double check that you have replaced the bulb with the exact lamp required.
Good Luck.
Nov 14, 2013 | Televison & Video
Dull picture
The picture is dull because your bulb is dying or dead or even the TV has come to that age that it no longer a vivid nice picture. A bulb with housing is around $150.
Mar 01, 2011 | Sony KP-61S65 61" Rear Projection...
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
We have a Discovery Wonderwall that has only been used a couple of times. Turned it on this evening and no picture at all. I have adjusted contrast and color in both directions and nothing. No light...
Did you figure this out? I have the same problem. We probabaly used it 10 times aand no video. I thought the light bulb may be bad. I picture a new one and still no picture. I know the video is hooked up properly. If you leave the back door (where you change the light bulb) off and shine a flashlight in there, the video projects on the screen. Something is wrong with getting electric to the light bulb.
Jan 26, 2010 | Televison & Video
I have an ipod 80GB with video out to the TV My 60GB willplay my pictures as a slide show on the TV, but the 80GB will not. Any Suggestions
You probably need different cables for the different ipod. Go to www.apple.com and click on the support tab; after it loads put the article HT1453 into the search. It will pull up the apple article on this exact kind of issue. It has pictures to show the different kinds of cables needed for the TV OUT feature on ipods. I found it very helpful, hope you do as well. Cheers :)
iPod and iPhone: TV out support Last Modified: January 02, 2009 Article: HT1454 Old Article: 300233
Apr 22, 2009 | Apple iPod MA446LL/A MP3 Player
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Rear right/left brake light don't work,top center brake light doe
Do the non working bulb holders have power at the bulb terminals?If not back track to the one that works.The flow of power or earth is bad and its probably happening between working and non working.Do you have a trailer plug?make sure the joins are secure.Maybe two wires touching?Have you put an earth to one of the bulb holders that dont work.Try taking the working bulb out and see if the others light up,Hard to do or suggest test without vehicle there to work on and makes it hard not knowing exactly what tests youve done but suggested a couple in the hope that theres something that helps.Good luck
Nov 17, 2008 | GMC Sierra 1500 Cars & Trucks
Horizontal Lines scrolling on screen
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Oct 31, 2008 | Televison & Video
Dull picture
I am having this exact problem with this projector. It has been doing this for over a year now. I am happy to see that I am not the only one. Not happy that you do not seem to have had any suggestions on how to fix it. We have even changed the bulb and the problem still persists.
Sep 18, 2007 | Sharp Notevision XG-C50X Multimedia...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
