Question about Sony PEGA KB11 Keyboard
Similar problem - several keypad letters have become corrupt
Several keys give numbers instead of the correct letters. Only about 10 keys are corrupt.
Any ideas?
  • fougzki May 11, 2010
    Do check regional language settings? Change setting to US language or what country you are in. Or your keyboard is at fault.
  • 11 Answers
It done u might need to replace it
Posted on Sep 11, 2009
I am trying to key text beginning with non-sequential letters/numbers. I cannot make Word quit changing what I key to sequential letters.
I am unsure which version of office you are using. This is a function of auto-correct. You may need to turn it off to stop this behavior, and turn it back on, if you need it to help you compose documents.
( My directions will be using Word 2007, which is what I have installed on my system.)
You need to open the Word Options panel. and go to Proofing.
GO into this location several times in a row, so that you can remember it better, and return to re-enable auto-correct. Uncheck the boxes needed to turn off this behavior.
Mar 19, 2014 | Microsoft Windows Vista Ultimate Edition
When typing using laptop keyboard pressing the letters u,i,o,p,j,k,l,m numbers 4561230 instead appear pressing the numlock keys or combination of shift key does not fix the problem
simple keypad contain problem,check it ask the place of purchase,because inside the connection may be changed or the layer of keypad bottom always touched the point other thing the keypad bottom a layer is not seated correctly...
Dec 24, 2010 | Computers & Internet
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
Why keyboard o number press 6?
The number lock has been selected, there is a LED light that is on to indicate the number lock has been selected. You will also find several keys when press will give numbers instead of letters.
Look at the keys above the function keys for the number lock key. some laptop keyboards use the Fn key plus the SCRLk key.
Jun 09, 2010 | Acer NSK8458AN Keyboard
Keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
Apr 13, 2010 | Lenovo IdeaPad S10-1208U Netbook
I cant undo the fn key on the mini note
You should be able to turn off the built in numeric keypad by pressing the fn key and the num lk simultaneously. The num lk is directly above the +/= key. If after doing this you still find you only momentarily turn off the numeric keyboard then there is another underlying issue. At that point you should take your unit to your area HP repair center.
Jul 15, 2009 | HP 2133 Notebook PC
Simply change my keyboard from typing numbers instead of letters..I.e. I'm trying to type yonkers and it gives me y6...I know it is a simple F6 or F2 function but I forget. Its been a while since I u
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Apr 26, 2009 | IBM ThinkPad T30 2366 Notebook
7290 with keyboard locked, used 9/10 goes,one go left of password
The easiest error is having the number, alt or caps lock on.
To check if this is the case, you will have an icon in the upper right hand of the screen.
Nov 17, 2008 | RIM BlackBerry 7290
Function Keys
hi there
you have lock the the number on the keypad to remove this function as caps on caps off simply press fn and key F11/numLK same time and it will return to normal letter function on your keypad
May 19, 2008 | Acer NSK8458AN Keyboard
Sony PEGA KB11 Keyboard Logo
104 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
