Question about Maytag Washing Machines
What is F29 Fault code on Maytag front load washer mod. WHWE500VW00. Plus Door won't unlock.
duby1990
  • 367 Answers
SOURCE: Whirlpool Duett Front load washer, DFL code door won't unlock?
Here are the steps to unlocking the door manually
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
SOURCE: error code 13 on my 5oo plus series washer, it
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Posted on Feb 07, 2010
  • 240 Answers
SOURCE: HE5t Kenmore Elite
non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
Posted on Jun 03, 2008
  • 240 Answers
SOURCE: Maytag washer mod # MAH9700AWW
means no fill, continuous fill of 12 mins. generates this. check water valves. if you do actually have proper water flow in and are getting this then check level sensor. a full tech sheet is avail at servicematters.com with info on checking components.
Posted on Jun 04, 2008
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Code f 29
F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you'll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad.
Aug 13, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error code F29 continually reappears on our washer which is only 4-5 months old. We have tried to troubleshoot the problem, but have had no success. HELP!!!!!
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get an error of f 29 and my door won't unlock
Hi
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Showing F29 ??
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated. Check the following:
  1. First, UNPLUG the washer in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that required in order to clear momentary glitches with the unit. If the error code reappears, proceed to step 2.
  2. Check the door switch/latch for foreign objects that may have become lodged in the mechanism and may be preventing it from operating.
  3. Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
COURTESY:JSROCK- A SENOR EXPERT OF FIXYA
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
May 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cannot unlock door, machine will not allow me run drain and spin
Unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). If the door still remains locked after a CCU reset, you can still open the door by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
NOTE: The "Fdl" and Fdu" fault codes are for older models of your washer, but the principle of accessing and releasing the door latch is still the same.
If your error code still persists, you may have to replace the door latch. Just follow the guidance in the link below:
If you still have questions, please let me know. I hope you find this information helpful.
May 11, 2009 | Kenmore Elite 45986 Front Load Washer
Code F29 is not in the booklet and I can't open the door, is there a way I can fix this because sears can't come out till Thursday, I have so much laundry to do
code f29 in my book is Door Unlock Error Possible causes/procedure are as follows: 1 door lock mechanism is broken 2. door switch/lock unit failure. a. check door switch/lock unit for foreign objects. b. unplug washer or disconnect power. c. check wire harness connections to the door switch/lock unit and central control unit (ccu) d. check door switch contacts E the resistance of both door coils between pin 1 and 3 should be approx. 320 ohms... the door can be unlocked manually... to do this you 1. unplug washer. 2 remove the lower kick panel (i think 2 screws on bottom hold it on) 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a 1/4 of an inch or until a click is heard. 6 you should now be able to open the door.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
HE5t Kenmore Elite
May 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
1,643 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
